Question about Lite On LVW-5115GHC+ DVD Recorder
Liteon LVW-1105HC will not record
On my recorder the door hang's up and i have to tap the top of the recorder to get the door to open could this keep the recorder from not going through the preparation stage it gets to 21 percent and then the door opens.I took the top off of the recorder and spray some can air in there to clean but did not help.
I had the same problem.
This is what worked like a charm for me:
Take off the top cover and locate the drive.
On top of the drive will be a metal plate with a plastic circle in the middle.
This holds the disk in place when spinning.
Locate 2 little black screws which holds the plate on.
Loosen the screws slightly until the the tray opens.
If it is too tight the tray gets stuck.
I put two tiny pieces of double sided tape, about 1/16 of an inch, as spacers next to the screw holes so the plate stays tight.
It may not be necessary but I did it anyway.
Good luck and I hope it works for you too.
Posted on Apr 11, 2009
  • mr_pez2000 Apr 11, 2009
    Im sorry I have a LVW-5115GHC+.
    it may work for your LVW-1105HC.
    It definitely cant hurt to try it.
I've got a LiteOn LVW-5115GHC+ and had the same problem with the draw sticking shut.
As mr_pez2000 says the problem is with the top carrier preventing the lazer mechanism from dropping to allow the draw to open. This could be due to the fact the top carrier (the metal bit attached by 2 black screws with a white plastic disc in the centre) could be bent down by the weight of other AV equipment pressing down on the lid which has some foam pads fitted on the top carrier causing it to deform over time.
The solution is to push up slightly the top carrier back to its correct position or put packing such as tape under the metal plate screw holes - it should spin when a disk is loaded. Make sure you don't put weight ontop or the unit after fixing or remove the foam pads.
I hope this helps you.
Posted on Jun 20, 2009
    Genius:
  • Lite On Master
  • 1,550 Answers
Change the motro charge belt is on the downside of the disc tray maybe are all the problem
Posted on Feb 14, 2009
2 Suggested Answers
SOURCE: My Liteon LVW-1105HC DVD recorder
I had the same problem, I had to open up the covers (including the one covering the lens) and clean the lens with a soft cloth. Please be very careful while cleaning the lens since it is very delicate and any damage would permanently disable read/writes.
Posted on Dec 16, 2009
Won't spin
Hello
The loading mechanism to your player is faulty. It doesn't engages the disc in to place perfectly. Replace the loading mechanism.
Mar 07, 2012 | Lite On LVW-1105HC DVD Recorder
Need instruction manual for Lite On LVW-1105HC
http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153
THe link is for the Lite On website. I believe I have found your manual.
Mar 07, 2011 | Lite On LVW-1105HC DVD Recorder
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Liteon LVW-5005 DVD Recorder. Disk drive door will not open.
give it a tap on the bottom as you press the button, this will force it to release the disc,
Jul 03, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
I need a Manual
hello i have uploaded this manual for you the link is below please leave me a rating if you found this info usefull many thanx nick!
http://rapidshare.com/files/190210152/manual.zip
Jan 27, 2009 | Lite On LVW-1105HC DVD Recorder
My Liteon LVW-1105HC DVD recorder starts to prepare the blank disc but when it reaches 21% of preparring disc it ejects the disc
Aug 23, 2008 | Televison & Video
Lite-On 1105 will not finalize when recording from timer
Hi Guys,
I have a liteon DVD recorder (1105) and I had the same problems......Exactly like yours.
So I opened the recorder and guess what??????? The light ray that burns the DVD was not moving.....I cleaned that thing that holds the light ray, so that it can move while burning and finalising.
The recorder is out of warranty any, so open it up clean it out.
Lennie
Feb 27, 2008 | Lite On LVW-1105HC DVD Recorder
Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Jan 27, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Lite On LVW-5115GHC+ DVD Recorder Logo
682 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
