Question about GE WBSE2090A Top Load Washer
My ge washer whdsr209d model wont agitate
It will spin and go through cycles but won't agitate and is it hard to fix?Thank you
  • 1 more comment
  • gtrg324 Feb 14, 2009
    yes the motor is running when it should be agitating.when i reach in and turn it it moves freely.both ways
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Is the motor running when it is supose to be agitating? If you reach in and try to move the agitator by hand, what happens?
  • Anonymous Mar 16, 2014
    My GE Lo-water washer has started to vibrate very hard and loud when it goes through both spin cycles. Model #GTWN4950LOWS.
  • 1,543 Answers
Reach down to the bottom of the tub and pull the agitator straight up and out of the machine. Sometimes this is a bit difficult. If so, slip a belt or rope under the agitator, attach to a 2 x 2 or similar object, and **** it straight up and out of the machine. Now, take the bolt out of the center part with a 1/2 inch wrench. Pull the upside down can shaped nylon part straight up and off. If it does not come off, you can crack it in parts with a hammer and chisel if needed. Try to turn the splined shaft with your fingers. If you can turn it, you are screwed. (need a new transmission) Most likely you will not be able to turn it with your fingers, which is good. That means that all you have to do is replace the agitator drive (sometimes called an air bell coupler) part number WH49X10042, reinstall agitator, and you are ready to go. Cheap fix.
Posted on Feb 15, 2009
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Apr 30, 2012 | Washing Machines
Ge washer whdsr209d wont engage spin cycle
It is probably the lid switch. you need to look for it, it will be somewhere where the lid meets the top of the machine. When you find it, bypass it. You will just have to be careful after doing this and remember that when you open the lid, it will not stop spinning or what ever cycle it is doing at the time.
Oct 15, 2017 | Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
GE washer model WWA8955 agitator won't spin. I can see the screw at the top of the agitator turning back and forth and hear the it running but that's the only thing moving. The spin cycle works. ...
The agitator connects the part (transmission) that makes it agaitate by a piece in the bottom of the agitator and that connecting part has teeth on it that interlock on the transmisson shaft. That connecter is stripped so when trans. agiates that peice is slipping. That coupler needs to be replaced. This video here will show you how to replace that part. The part number for that peice is WH49X10042 it could be purchased at your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
assuredparts.com
I hope i have been able to help you fix your washer,GENE
Aug 15, 2011 | GE WBSR3140DW Top Load Washer
Won't spin
If a washer will agitate and wont spin check the lid switch. Lid switches are designed to not allow spin on most washer but will allow agitate. Safety feature.
If you need further assistance please feel free to comment me back.
Jul 27, 2011 | GE WBSR3140DW Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE WBSE2090A Top Load Washer Logo
433 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
