Question about Xerox WorkCentre M-24 Color Copier
Quality of printed color copy
The printed color copy quality is not very good; the printed copy looks unbalance; one side is lighter than the other.
  • Anonymous May 11, 2010
    would be very helpful to know the details of the type of printer??
Sorry, I didn't notice that you had indicated the model. This machine likely needs a technician to clean the unit...primarily the laser optics, and transfer sections, I would say
Posted on Feb 14, 2009
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
I have change the toner of Hp Color laserjet 2600n but when i print some thing then its print very light
check the supply status, if its good perform calibration, if not satisfied go to menu-quality-increase the density of each cartridge then check the quality,
if you are tec guy: if print quality both sides lighter, middle is normal open laser scan assm, clean reflect glass with ear buds/ smooth dry cloth/ leather cloth then check the quality ensure that not to touch any factory align settings...senior professional only perform this activity, strongly not suggested to juniors/ hobbyists..
Sep 09, 2011 | HP Color LaserJet 2600n Printer
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
6-part NCr paper form being used. Pages 1 and 2
This is a problem with your paper. Using multi-part forms on an impact printer will get lighter print on each layer working from the top form to the bottom. The "carbon" paper has to impact the paper hard enough to make the marks. If your top and bottom copies look good but some in the middle are light it is a problem with the "carbon" paper and not the printer.
Now IF the top page is light and each copy under that is getting lighter then you need to close your platen gap (the lever on the right side of the machine mark A B C) go one click at a time (darkening) until the print quality looks good (or you go too far and it pinches the paper and jams *not good*)
Feb 16, 2010 | IBM Infoprint 6500 Matrix Printer
Color looks blauchy. all consumables are at a good level. what I should?
check the fuser rollers for wear also lift the lid and look at the mirrors on the scanner unit to see if there is and dust on them as this affects the copy quality if you are using for printing check the difference in quality if the prints are better the problem is in the glass copy area could be dust or paper dust on mirrors.. if not the drums or transfer could be worn have you had it serviced if not that may be required
Jul 28, 2009 | Minolta bizhub 350 Black and White Copier
Color and black gets shadow on print out
Go to the printer Setup button, hit Ok, then look for Print Quality, acess print quality and go to calibrate colors, run this calibration for 3 times.
Then go to services and run a 2 cleaning modes
You can try printing blank pages selecting "cardstock" as paper type to clean the fuser
Mar 16, 2009 | HP Laserjet CM2320nf All-In-One Color...
Color printed copy appeared unbalance, one side is light.
Please do the following
1) Take the Ink cartridge out and shake it well.
2) Wipe the print head with a tissue to eliminate all dried ink particales.
Once dont please insert the cart ridge again and try printing
Please rate the fix
Feb 14, 2009 | Xerox WorkCentre M-24 Color Copier
Print Quality
  1. In Windows, click on the Start button and choose Control Panel.
  2. Choose Printers and Other Hardware from the menu that opens.
  3. Choose View Installed Printers or Fax Printers.
  4. On the window that opens, look for your printer's name. Right click on the printer's icon and choose Printing Preferences.
  5. On the Print Quality tab, choose Draft or Fast (varies depending on the printer).
  6. If you want to conserve your color ink, choose Grayscale Printing on the same tab (just remember you'll have to uncheck that box if you want to print something in color).
  7. Press OK. That's it; now your printer will automatically print in Draft Mode (and in grayscale, if you chose that option) until you change it back. To change it, simply follow the same instructions and choose Standard for print quality
Jul 22, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Xerox WorkCentre M-24 Color Copier Logo
70 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
