Question about Combi Centre DX - Mango
Ariston Micro System type c bolier
Hi
No more heating as the pilot light is out and it does not heat the water or radiators any more? I have pressed the reset button but the flames do not ignite and the heater just makes a whirring noise. It is very cold can anyone help me figure how to get the thing igniting again?
Thanks
  • 10,865 Answers
Go to this site and you can download the manual you need
http://www.gotoplumbing.co.uk/findamanual_results.asp?catid=3146&accid=980
Posted on Feb 14, 2009
WHY CAN I GET HOT WATER BUT THE RADIATORS WONT HEAT UP- BAXI SOLO 2PF SYSTEM?
check the pump see if this is working and the rads are open
Oct 05, 2012 | Heating & Cooling
I have a Worcester Bosch HE system boiler. I am not getting any heating or hot water.The burner ( pilot light) is not on and the pressure gauge is on 0 bar. The boiler is about 7 years old. My decorator...
If a radiator was taken out and put back in I feel you have air built up in your system. There should; be an air relief valve on each radiator. Get your furnace up to heat and open the valve on each radiator till all the air is out of the lines. If there is air in the system there will be no heat. You do this after the heat is on. As far as the pilot not coming on you could have a bad igniter which may need replacing to get heat.
Aug 22, 2017 | Water Heaters
I have a Biasi Riva Advance HE Combi Boiler. The pilot light and fan dont seem to be working, I can hear a click when I run the hot water tap and a click after I turn tap off,
Have you bleed the air from system and run hot water and heating at the same time , bleed the pump . you could have air in the pilot after turning it off
May 01, 2017 | Water Heaters
We own an apartment building that has the old radiator steam heat powered by a gas bolier .. It heats 11 apartments and 3 store fronts. recently 1 of the apartments called and said that they were not...
the steam is not flowing to that radiator because of a blockage in the pipe or radiator, the valve may have an obstruction or the radiator is water bound. Remove the vent and see if the heat improves. If not, you have a blockage in pipe or valve.
Jan 08, 2011 | Heating & Cooling
Ariston Micro genus 11 Only getting hot water no central heating
Check the heat exchanger. Often they and gummed up.& you will have to try & flush it out or replace. If this model has the cylindrical type, they are pigs to do.
If this machine is 10 yrs old or more, you might find it better in the long run to have a new boiler
Just a thought, but I assume that the valves on the 3/4 " central heating pipes are turned on
Parts to look forward to later - fan £80 - pump £65 - heat exchanger £110 - diverter valve £65 - pressure relief valve £45
Mar 14, 2010 | Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Ariston combi boiler
sounds like your diverter valve is passing on the boiler, this diverts the heat either to the rads or to the taps, if its passing through the heating chanel it'll heat up the rads- may also be a scaled up secondary heat exchanger, hope this helps you
Aug 21, 2008 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
326 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
