Question about Refrigerators
Refrigerator is about 54f, but the freezer works and is icy
We came back from a trip to discover that everything and every surface in our top freezer was covered in long ice crystals. The ceiling of the refrigerator had frozen water on it and there was water dripping into puddles on the top fridge shelf. Since then the fridge has stayed around 54f when the room temperature is about 65f. We've turned it all the way up which has not helped. The freezer is still cold (very cold) and it doesn't seem like anything melted in there.
Did the compressor die? I'm trying to find out if there is an easy fix, and expensive fix, or if we should just get a new one.
  • 21 Answers
Posted on Feb 14, 2009
Light came back on in older 18cu.ft. Frigidaire (freezer on top) refrigerator after lightening storm tripped a GFI plug on the circuit but no cooling or freezing No sound of motor running.
As the light works the supply is obviously ok.
It would seem to be time to find the reset button if there is one and try pushing that. If no reset button or it doesn't work the circuit and supply will need tracing through with a meter and/or a test lamp in order to discover the fault.
Apr 29, 2016 | Frigidaire Refrigerators
Have a amana with bottom freezer. Everything
Keep in mind, your fridge 100% depends on the freezer. You have a defrost system problem most likely(see if icying up in the back wall of freezer). And if so, most likely defrost thermostat went bad.
Amana refrigerator repair orange county, ca
Feb 06, 2010 | Refrigerators
Cold air not getting from Freezer to Fridge
I actually know nothing about refrigerators, but was able to fix the same exact problem where cold air was not getting to the fridge side of the side by side. The freezer was working just fine. I unplugged the fridge and freezer and tore all the shelving out to get behind a panel in the back of the inside of the freezer. There is a pass-through between the freezer and the refrigerator at the top back of the freezer on the side-by-side refrigerator. The passthrough was totally frozen over and blocking air from passing through and cooling the refrigerator side. I let it all de-thaw and then was able to pull the chunks of ice out, and all seems to be working great now. Be careful getting the ice chunks out as there are some controls there - it's probably best to just let it all thaw and melt by itself - which wouldn't require tearing all the shelving out. One could simply let the freezer dethaw for a day and then plug back in and both sides should work just fine.
Aug 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Jul 28, 2009 | Refrigerators
Light is on but fridge will not run
there are certain posibilities as the pa refrigerator needs electricity. If the refrigerator's light doesn't work and it's motor doesn't run:
1) Check the power. Make sure the receptacle works (plug in a working lamp or a circuit tester). If the receptacle doesn't work, check for a tripped circuit breaker or blown fuse.
2) Be sure the cold control is turned on.
3) If you discover that the refrigerator is plugged into a working outlet and the cold control is on but the device shows no signs of life, leave the door closed to retain the cold air and call an appliance repairperson
Jul 13, 2009 | Frigidaire FRT18S6AW Top Freezer...
Freezer and refrigerator run but is not cold
Remove the back panel at the bottom. The refrigeration system is a sealed system and the smell would not come from it internally. Check and make sure the fan motor is running. If the fan motor (was) shorted out it would account for the reseting of the breaker. After resetting the breaker a number of times would cause the circuit in the fan motor to open allowing the compressor to run. Is the small line coming out of the compressor hot? If so replacing the defective fan motor may correct your problem.
May 03, 2008 | Refrigerators
unit has reached its life expectancy. tilting causes oil to move into the condenser and is damaging in itself, newer units can survive moving, but when you expect both units to recover,i have to recommend replacement
Apr 07, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hotpoint 8496p fride not working
I had a similar problem with a top freezer and it was discovered that the fan had actually slipped down on motor shaft and was stuck against the freezer wall. Check to see if there is enough clearance for the fan to actually spin.
Jul 22, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Andeb, couple of things you want to check. Is the fan in the freezer section running? Take the lower back panel off and see if the condensor fan is running as well as the compressor. As long as you tilted it only slightly I would think this is a fan or overload relay problem. Check the things I mentioned and post back...Catriver.
Aug 21, 2006 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
