Question about Canon LV 7345 Multimedia Projector
Bp6110 projector powering on but no lamp.
I recieved this projector used from a friend who said it worked great. I plugged it in to my lab top and the projection kinda went black with red lines now I can get the projector to power on and that is all. Help! I dont know anything about projectors so is this just a bad bulb?
  • 119 Answers
SOURCE: Projector does not turn ON
try removing the lamp, usually quite easy, you need to find the door for the lamp. lamps are customer replaceable, usually. If the lamp is bad you can usually see it damaged in the lamp. kind of like you might be able to see the broken filament in your normale house hold light bulb. good luck.
Posted on Dec 24, 2006
marsrover
  • 682 Answers
SOURCE: Bad Lamp lights even with new bulb.
confirm that it is not made in china-because some chinese lamps is not good in life time.
Posted on Mar 07, 2008
projdoc
  • 2237 Answers
SOURCE: Projector won't power on. Plug it is and all I get
the lamp is past 2000 hours and needs replacing and the timer needs resetting.
Posted on Aug 18, 2009
SOURCE: I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
Posted on Nov 23, 2009
SOURCE: Projector turns off
Still looking for answers....anybody????
Posted on Jan 24, 2010
I have plugged in a Optoma HD600x-lv, and nothing. No motor or lamp. Dont have remote, so pressing power button on top. Nothing. Any ideas?
I'm assuming the warranty is expired. But if the projector doesn't respond to direct power, you'll have to have the circuit board and power supply checked out.
Only other option might be to ensure you have the power cord plugged in thoroughly or swap it out.
Nov 13, 2014 | Optoma Projector Hd600x-lv
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
My dell projector 1800mp is not powering up. No light comes up at all after plugging to outlet
The first possibility is the projection lamp itself. Since you have not mentioned about the hours used on the projector I ccannot comment otherwise but if you have used more than 250 hours then there is a possibility that the lamp is fused out. If you have any friends having the same model you can swap the projection lamp and confirm. The next possibility can be that the filters are choked, the power supply used in the projector - the smps- could be a possibility. Only if you have experience in electronics should you probe into the smps unit/ control board or seek help. lets Hope the fault could be the lamp itself. Good day
Aug 03, 2010 | Dell 1800MP Projector
BENQ PB6110 - will not power on
Hi I am Vortash check the lamp housing is secure as most units have a safety switch on them to disconect the projector from the supply while a bulb is inserted .. I fthis is secure and the fuse is not blown I suspect the lamp or the ballast .. look for dry joints on the board for the lamp or unseated plugs other than that unless your friend can trace the psu switch mode power supply back to it's individual outputs and check that it is working correctly your going to have to take it to an engineer sorry .. hope this helps Regards Vortash
Apr 15, 2009 | BenQ PB6100 Multimedia Projector
Optoma EP Portable Projector - No Power
if the lamp asssembly isnt screwed in tight the unit will not power on. i did have a faulty lamp once, try fitting the old one back to check first. if not the power supply is faulty on the main board or a short in the supply to the lamp can cause this fault.
Nov 01, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Projector shut down
Hi
Replace the lamp, or better yet try removing and reinstalling the lamp.;
Hope this helps
Nov 01, 2008 | BenQ PE8700 Multimedia Projector
When I put power to my LP530 all I get is a tickin sound
pull the lamp and see if it hasnt blown. if it has replace. the ticking is the lamp trying to strike.
Jun 24, 2008 | InFocus LP 530 Multimedia Projector
No power
yeah i had same problem where the power would not come on. literally nothing, no green light, no power button, nada. I was able to fix it for under $20. I got a soldering iron from a friend, some solder, and a toolbox with a hexascrew or sectascrew or whatever it is that has six (i got mine from radio shack) starpoints. so basically took it apart which was complicated but totally doable. then i took off the top motherboard thingy and then was able to unscrew the power supply board which is about 2 inches squared. taking this off i was able to look around on it and visibly see one of the circuits on the bottom was blown. so i just re-fused it with the soldering iron. it was the first thing ive ever soldered and i was capable of doing it so it cant be that complicated i guess. anyways, that got it working again. didnt break anything to open it so why not give it a shot?
Jun 13, 2008 | InFocus LP 250 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Projector not recieving input signal
eeek matt. an ally olly, (means garlic mayo in spanish)
never mind, i'll try to help.
first check out all signal in options, are you sure pj is receiving a signal in. use all available input option to check out.
if no joy proceed carefully as follows
power down,openup pj and check by inputs pcb panel.
probably a mini plug has fallen out or a slidein flat cable is not fully plugged in
good luck with the faultfinding
Dec 16, 2007 | Office Equipment & Supplies
Canon LV 7345 Multimedia Projector Logo
95 people viewed this question
old marine
old marine
