The picture looks like a bad vcr tape is in - need tracking
It is about 14 years old and it looks like when you used to have to adjustthe tracking with a vcr, you cannot see a picture just the lines across the tv
  • 21 Answers
I hate 2 say but 14 years you got your moneys worth Time 4 a new one
Posted on Feb 14, 2009
Buzz during playback, but only on SOME tapes!! When i adjust tracking manually, pictures quality suffers.
Bad recording VHS or old VHS tapes,will sometimes causes this problems,because of degrading magnatic tapes.Sorry this problems,u did the fixed adjusting manual tracking,that it not fixing the problems,sorry that all u will getting that kind of quality of picture.
Mar 21, 2011 | GoVideo Go Video DVD/VCR Combo
Iv got some old vhs tapes and when i put them in the vcr to play they jump and give a fuzzy picture can you help me please. thanx
All you can do is adjust the tracking and make certain the video head is clean. I would have a look inside each VHS tape at the tape itself, it might have got mould or damp inside it.
But if the video machine plays back it's own tapes and commercial tapes OK, it could be the tapes have gone bad.
Dec 06, 2010 | Sony Televison & Video
My jvc has developed a tracking problem when viewing tapes recorded on other recorders. I cant seem to correct the problem. It shows old tapes without a problem
VCR tracking has to be set up right, but even then many machines have problems with tracking other vcr's tapes. Generally a good quality commercial tape should track well. If it doesn't then either there's a fault with the tracking on your machine or the tracking is not set up right. Most tracking problems are caused by dirt, or wear on the heads or surfaces. Give your VCR a good clean up, every surface the tape comes into contact with, using Servisol Video 40. If that doesn't solve it you might have to look into the cost of replacing heads, maybe the control/audio head first. Or you should look at having the tracking set up by a proffessional (at a JVC service center). However if the tracking was off, after resetting any tapes the machine has done, may now have problems tracking, whilst other machines tapes and commercial will track normal.
Jun 28, 2010 | JVC HR-S6970 S-VHS VCR
When playing a vhs tape the pics jump half way through watching. trying to record these old family tapes to dvd. is there a type of vcr i can buy to manually fix tracking or is there another way to solve...
There are two reasons that might cause loss of tracking halfway into a video tape. The first means you can't really do a lot about it. To check it is this is simple. When you get to the point the video jumps, stop the VCR and eject the tape. The look at the tape itself by lifting the flap at the front (push the small catch on the right side). Examine the section of the tape. If you see any damage to the tape (it should look smooth and shine) then it will never track properly.
Another cause of the jumping is caused by the take up reel, getting sluggish. Sometimes these are run off a belt, that becomes slack, replacing it could solve the problem, or it could be something else in the mechanism that's causing it.
There is another solution, particularly if the tape wasn't recorded on the machine that is playing it back. I haved used loads of different VCR's and I found that the tracking has never been set up right on any! This means that only the VCR it was recorded on generally gives the most correct playback.
Having said that it is possible to get a VCR with really good tracking. I have found that Panansonic VCR's have the best tracking. I currently have a NV-HS900 which can track just about everything, but you will only get one seconed-hand now.
Apr 07, 2010 | Televison & Video
Picture bounces up and down
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Dec 15, 2008 | Sylvania 6240VE VHS/S-VHS playback VCR
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Picture blinking on a Sharp Quos HD TV
Is the VCR sitting on top of your TV? This has caused problems in the past...accordianman
Feb 18, 2008 | Panasonic PV-8400 VHS VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Vcr record problems
It sounds like the back tension is off on the unit. the back tension is controled by a small band attached to a copper or metal strip and that ia wraped around the supply reel and is adjust by an arm that swings out and contacts the tape during record or playback and keeps a steady tension on the tape. If the back tension band breaks or wears out you will get a picture that looks like the tracking is off or bad or dirty video heads. Most likly you do not have a backtension gauge and it certainly would not be fesable for you to purchace one as a good one cost about 100 bucks or so. A repair shop may beable to adjust it for you, But even their fee may be cost prohibitive. Good Luck PS please do not forget to rate this.
Oct 14, 2006 | Sanyo DVW-7200 DVD/VCR
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
