By Rogers - usenet poster
Specifically to a Brother MFC3820cn - #
Im currently trying to print to it via CUPS, but Im getting nowhere fast.
Has anyone ever attempted to print to this unit via the network?
I would like to hear what you have to say...
Thanks
Solution #1
posted on Aug 01, 2007
Cato - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Hear hear...
I have actually upped the ante to LPRng which adds multi printer print
queues and more network capability all round and also use the related
ifhp filter ...
Printing just fine at home from the FreeBSD boxen, and via a SAMBA
[printer] share, a Win98 box and a Win2K laptop also print Ok too.
And at work I am printing via LPRng to the array of variant HP things we
have and to a barcode printer running a serial protocol via a Troy
Serial Server box on the network. It looks like a standard network
capable printer thanks to the Troy box ie you set up the
hostname:9100 address:port like any other network LPD printer in the
printcap file, then print as shown.
$ stdbarcode 24004 15000 | lpr -Pbarcode
and some short time later we have 15000 barcode labels.
FBSD +--ethernet lpd protocol---+ SServer +---rs232---+ barcode prt |
cheers
mjt
ps
The OReilly book on 'Network Printing" is also a very useful reference
And if you are going mega - there are some articles on enterprise
printing done at Cisco, using LPR and some clever addressing and
grouping to maintain high availability.
Go Google...
Murray Taylor
Special Projects Engineer
Bytecraft Systems & Entertainment
P: +61 3 8710 2555
F: +61 3 8710 2599
D: +61 3 9238 4275
M: +61 417 319 256
E:
or visit us on the web
This Email has been scanned for Viruses by MailMarshal.
ifhp filter ...
cheers
mjt
ps
Go Google...
Murray Taylor
P: +61 3 8710 2555
F: +61 3 8710 2599
D: +61 3 9238 4275
M: +61 417 319 256
E:
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Charlie - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Every so often I see someone or more than one someone struggling with
CUPS and I have to ask myself "Why?". Why can't you use LPD? It's
pathetically simple: so simple that even I have a networked printer
working nicely. I remember going through months of pain with CUPS.
And that was with a local printer! Maybe thirty minutes with LPD (ten
if you don't count my initial, uninformed choice of an any-to-PS filter
which gave unexpected output) and I have a perfectly functional
networked printer. The LPD documentation in /usr/share/doc/smm/07.lpd/
is extremely helpful, as is the Handbook,
# , and of course the manpages. I actually
printed "4.3BSD Line Printer Spooler Manual" (the doc in smm/07.lpd/)
when I setup my printer, and I'm very glad that I did.
If it's a licensing issue, then you're using the wrong OS.
I abhor a system designed for the "user", if that word is a coded
pejorative meaning "stupid and unsophisticated". -- Ken Thompson
Unix is user friendly. However, it isn't idiot friendly.
Please CC me in all replies, even if I'm on the relevant list(s).
application_pgp-signature_part
1K
1K
Solution #3
2Pansy - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Are you sure this is needed? I don't think I have ever done this, though
my CUPS installation is happy and running fine.
But for those who also rebuild world every now and then, they better add
this to /etc/make.conf:
CUPS_OVERWRITE_BASE=yes
NO_LPR=yes
before building world and installing CUPS.
Urgh, a 'reboot' is the very last resort to get this up and running.
./cups.sh {reload|restart|start|status|stop} should be advertised here!
Good work to start a CUPS tutorial for newcomers to the OS.
Cheers,
Rob.
NO_LPR=yes
Cheers,
Rob.
Solution #4
Reynolds - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Dear Gerard,
I too have struggled with making CUPS work for network printing. It took me
awhile, but I think I've finally got it. The FreeBSD Handbook has nothing useful
to say about CUPS (it just says visit #), so I've been writing up
a HOW-TO which I'll submit to the Handbook folks soon. It's not quite finished,
but here's what I have so far - hope it helps.
regards,
Robert
STEP 1: Installing CUPS from PORTS
You've got to install four packages from ports. You can find them here:
root@sonic:# ls -d1 /usr/ports/print/cups*
/usr/ports/print/cups-base
/usr/ports/print/cups-lpr
/usr/ports/print/cups-pstoraster
The first port - /usr/ports/print/cups - is a meta-port, so installing it should
install the others.
STEP 2: Creating a Log Directory
Create a directory for the CUPS log files:
root@sonic:# mkdir /var/log/cups
STEP 3: FreeBSD-specific Issue
On FreeBSD, CUPS stores its executable files in /usr/local/bin/ whereas the
traditional lp executables are in /usr/bin/. Because /usr/bin/ is in the command
path before /usr/local/bin/, your CUPS files will not be able to execute. For
example:
root@sonic:# which lpr
/usr/bin/lpr
This problem is handily solved by making file /usr/bin/lp* non-executable, like
this:
root@sonic:~
Now, let's try the previous command again:
/usr/local/bin/lpr
Success! This is what we want.
STEP 4: Starting the CUPS Daemon
You need to set up a script that starts the CUPS daemon on bootup. There is a
sample startup script which you can just copy and make executable, like this:
cd /usr/local/etc/rc.d cp cups.sh.sample cups.sh
chmod 755 cups.sh
You could reboot now to start the daemon, but since you're in this directory
anyway, you could start it manually:
./cups.sh start
STEP 5: Configuring the Printer
This part is just like Linux. Open up a browser (Mozilla or Konqueror will do)
and type this url:
This will bring you to the CUPS configuration menu. You'll be asked to login
(login as root and use the root password), then it's simple point-and-click
stuff that you should be able to figure out yourself.
STEP 6: Configuring a CUPS Server and Client
If you want to enable network printing on your LAN, you've got a little more
work to do. Assuing that the FreeBSD box is the print server, edit file
/usr/local/etc/cups/cupsd.conf and make two changes. The two changes vary
according to how your network is configured, but for a typical Class C network,
this should work:
# broadcast address
BrowseAddress @LOCAL
<Location / Allow From 192.168.0.0/24
Instead of @LOCAL, we could have specified a broadcast address, such as
192.168.0.255 (again, that's for a Class C network). And rather than
192.168.0.0/24 (the whole network), we could have specified just a single client
machine (such as 192.168.0.3).
Once you have made the above changes, restart the CUPS daemon:
/usr/local/etc/rc.d/cups.sh restart
Now go to the client machine, open your browser, type #, and
click the button "Print test page" - it should work. Now try printing a regular
html file with the same browser. It will probably NOT work unless you remember
to specify the CUPS server as the printer (your browser should give you an
option to select a printer in the "File-Print" menu).
STEP 7: Configure a CUPS Server to Work with LPD Clients
If the client machine is not running CUPS, or you are using an application (on
the client machine) which depends on lpr, you must configure CUPS to accept
print jobs from LPD clients. You accomplish this with a CUPS helper server
called "cups-lpd" (see "man cups-lpd").
Suggest a new solution for this problem
Post a New problem for Brother MFC3820CN Print Server
Email this problem
Email this problem
Can you Help with these Print Servers problems?
MFC3820CN - Error 33 -...
h e e e l p; contacted brother... Answer This...
Repair Service
Find Print Server Repairman Near You:
