F&P GW712 Washing Machine Error Code 49
I have this error code coming up on my washing machine. I found out that a fast blow 1A fuse was dead and replaced it. It's the round red one which goes to the water solenoids. After replacing it, I powered up the washing machine and still the same error but this time the cold water solenoid blew up. Before replacing the fuse, the solenoids were reading 60 ohms each. Unfortunately the replacement fuse that I had was 1.5A and the solenoid blew up before the fuse. Any help would be much appreciated
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Washing Machine is not getting cold water
The solenoid comes as part of the fill valve assembly. It's fairly simple to replace, but before you attempt replacing the valve try turning off the water supply and disconnecting the hoses from the back of the washer first. Inside the valve assembly on the back of the washer are water valve screens. These screens can get clogged with sediment which will restrict or stop water flow. If you've never checked them or cleaned them before this could save you a little bit of repair time. Simply use some distilled vinegar and a cotton swap and thoroughly clean each screen. If the valve still does not produce water flow, the part number is 878761 an runs about $25. Let me know if this helps you.
Posted on Sep 22, 2007
SOURCE: Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Posted on Jan 13, 2009
sonicboomele
  • 1557 Answers
SOURCE: Error Code 49 Fisher and Paykel Washing Machine
the code error (49) is telling you that the inlet valve is not working make sure the hoses are not blocked. if you have fitted the valve and is still not working then i would try using the unit on cold if it still does not work then there must be a short in the p.c.b control board.
hope this helps a little more
Posted on Jul 12, 2010
Jahn27
  • 1554 Answers
SOURCE: Whirlpool ghw9100 Door lock solenoid 60 ohm and
The terminal numbering of the door lock and unlock solenoids solenoid looks messed up and your resistance reading is correct and the solenoids are good as long as you get 60 ohms both on 3-2 and 2-1 and 120 ohms on 3-1.
You stated, as per live chat discussion, that the door never locks to start a cycle. The door locking routine starts only if the door switch contact is closed (refer to page 6-2 of Job Aid L-68). This could mean the door switch contact never closes for the door locking routine to be initiated and a wash cycle can start or the CCU is not detecting it closed.
Check the continuity of the door lock and switch assembly wire harness (door switch, door lock main switches, and solenoids wire harnesses) including the connectors. Replace the wire harness if a discontinuity or any other issue that might jeopardize its function is found. Proceed with the troubleshooting if no issue is found with the harness or if the problem is not resolved with the replacement of the harness.
Reinstall the door lock and switch assembly, reconnect the wires, put the door gasket back over the outer lip of the door opening, and close the door. Reconnect the door lock main switches and the door lock/unlock solenoids harness except the door switch harness. Jump a wire between the door switches terminal connections (adjacent terminals) on the central control unit (CCU) then reconnect power and start the machine.
The door locking routine should start and eventually lock the door and start the cycle if the issue is with the door switch not closing. Replace the door lock and switch assembly if that is the case. The problem is in the CCU not detecting the door switch closing and needs to be replaced if door locking routine still fails to start, lock the door, and start the cycle.
If the door locking routine starts and the door lock seems engaging but fault code "FdL" flashes and the door is locked, unplug the machine then check the continuity of the door lock main switches at the wire harness connector in the CCU (refer to page 5-3 of Job Aid L-68). The problem is also with the door lock and switch assembly if there's no continuity in any of the door lock main switches. Otherwise, the problem is in the CCU not detecting door lock main switches closing and needs to be replaced if there's continuity in the switches.
With the fault "FdU" flashing when the door lock main switches bypassed, the CCU is certainly detecting the switches closed. This eliminates the possibility of the CCU not detecting the door lock main switches closing. It leaves only the possibility that the door switch is not closing or the CCU is not detecting it closing.
Posted on Sep 23, 2010
Fisher @ Paykel GW 712 washing machine error code 49?
My sister discovered her cold water was turned down,,however a plug or pinch hose could give the same code on fisher/paykel. Check your owners guide for your model.
Jul 27, 2015 | Fisher Washing Machines
Gw712 doesnt start just beeps
Lets see if an error code pulls up.
With the machine off, press and hold the Wash Temp Down button and then push the power button until the machine gives 2 short beeps and lights up. Now press the Spin Speed Up button three times so that the Hold and Slow LEDs are illuminated.
The eight wash progress LEDs will show the error code.
Apr 29, 2014 | Washing Machines
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Mar 19, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Gw712
66. (01000010) Phase 6 - Pressure Transducer (Ptx)
Error - Frequency > 90 kHz
Note: this supersedes Fault code 65 from V41 Motor Control Module
code onwards.
The Motor Control Module has received signals from the water level
sensor (Ptx) above normal frequency values.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Apr 22, 2012 | Fisher Paykel EcoSmart GWL15
Error code 49 on gw712 washing machine. constant beeping when turned on, lights 3,4 and 8 on. beeping stops once a button is pushed. If start button is pushed, lights go out and lid lock light...
Ive been told that this is a faulty cold water valve. Just got of the phone with F & P as my machine is doing the same. Bout $60 to replace
Apr 28, 2011 | Washing Machines
Jul 12, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machine won't work
Sounds like error 49.
A water solenoid. I bought mine for $40 on ebay. FP didn't want to help. I still had the same problem after so I did a bit of chasing. I wasn't going to pay $350 for a controller, they must cost about $30 to make!
If you look closely at the solenoids you may see a bulge or burning.
I replaced the solenoid but still had binary 49 LED code. I chased the circuit through the Motor Controller (brown one in Australia) GW712.
It was a couple of FETS or Qs in a H drive. The get fed their +v from the main power rectifier. There is a funny looking round component called F^ which is a quick blow 1.6 A fuse. Because my solenoid had a shorted turn on it (bubling to outside packaging) it had blown this.
I didn't have one instock so I substituted an ordinary glass 2AG 2.0amp fast blow. You need to remove the old fuse and solder 2 wires into the holes left these are inturn soldered to the fuse ends. I used hot glue to hold the fuse clear of any other components.
You can get slow blow fuses almost anywhere. In my experience ordinary fuses are the same they always fail after the components are lost anyhow!
If you are desperately dirty you could just jump the 2 holes with tinned copper but this could represent a fire hazard if a solenoid goes again.
We amke microcontrollers. It is a simple fix and saved me $350. A fuse is 10c or maybe $1 if you buy them one at a time. Make sure you test the plugs before you start up. My GW712 read:
1. Each motor winding ~ 35 ohms to any other
2. The lid solenoid ~ 70 ohms
3. Each water solenoid ~ 60 ohms
4.The thermistor ~ 10K ohms
# When this fault exists you can empty the water by removing the tube to the Pressure Xducer and using a tube from your mouth to blow into it HARD!!! The pump will start and pump it out for you.
To calculate the error code (for what use that is when you can find out)
LEDS indicating wash cycle
X X X X X X X X
128 64 32 16 8 4 2 1
Add the values for each light LED
Mar 18, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel GW712 Washing Machine - beeping & flashing continuously
my gw712 washing machine will fiil up ok but then it wont spin properly it only spins a fraction then stops and starts beeping the second led from the left starts flashing. any help would be greatly appreciated.
Nov 11, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
