Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
RUNDLL Error loadin
When i first turn on my computer and it starts loadin up my desktop. A bow popps up n says.
Error loading C:windowssystem32qhpskbsm.dll
The specified module could not be found.
How do i go about to fix this problem?
  • nevetsnosdoo Feb 14, 2009
    It does not appear while in safe mode. And i dont have a recovery Cd
  • 60 Answers
Do you try safe mood ? If this startup msg dont appear in safe mood than the solution lies in microsoft configuration utility(msconfig}. Let me know what happened in safe mood.
Posted on Feb 14, 2009
  • Prosun Pal
    Prosun Pal Feb 15, 2009
    There is your solution. Click "Start"----Run, type 'msconfig' without quote and press enter. Uncheak all items in the service tab. Restart. If it does not happen than you run "msconfig" again and check one item in startup tab. Restart. Keep checking one by one untill the problem appears again. If you found that startup program that causing problem; uncheak it permanently. Dont forget to restart after every uncheak. One more thing, your currently installed one specific program is causing the problem. Find a clue from the startup item that causing problem and uninstall that. Hope thats enough for your solution.
    Keep informing.
    Sergeant:
  • 183 Answers
If you have recovery or OS disk then
insert in cd/dvd drive
then
click on start>run
type is "sfc /scannow" without quotes hit enter
and let your procedure finish
once its done reboot your pc.
Note: there is space between sfc and / .
post back if it makes any changes and rate all anwers.
good luck
What does "RUNDLL Error loading newdev.dll" and
newdev.dll is the Windows file that is responsible with the recognition of the hardware and the loading of the drivers - an absolutely critical file. This file is severely corrupted and the only way to fix that is to perform a Repair install.
Dec 15, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
Everytime I start up Windows I an error message.
Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
How do i fix rundll error load c windows
For that open cpu cabinet then refix RAM memory.
Then when you power up the computer press F8 key then neter in safe mode.
Then go to start menu->run
Type in run "chkdsk /r"
then press "y"
then restart then it fix error.
But if you not able to enter in safe mode then you need windows or recovery disk.
Boot your computr with disk and follow the procedure and choose "R" option for repair windows.
Nov 10, 2009 | Dell Dimension 3000 PC Desktop
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
RUNDLL Error Message, Windows XP
Dear sir,
Welcome to Fixya.
Rundll error is observed when computer is attacked by viruses and spyware.I think your computer is infected by virus and spyware.You can remove the viruses and spyware by using good Antivirus software,but if you want to get rid of all errors permenantely, solution is format your pc and reinstall your operating system then install good antivirus.
I think it helps
if you have any problem regarding this issue leave a comment or feedback we were happy to assist you.
Have a Nice Day!
Oct 02, 2009 | Dell Dimension E520 PC Desktop
Cannt do any thing
use a good antivirus software to scan the machine. you may have a Trojan.
Trojan usually use the rundll to install itself.
Dec 01, 2008 | HP dc7800 Business Desktop USDT Alternate...
RUNDLL Error loading c:/PROGR-1/MYWEB-1/bar/2.bin/M3PLUGIN.DLL The specified module could not be found Can you please help me how to get rid of this at the start up please. Thax Tracie
This is a virus download " Malwarebytes " and install and run it will delete all virus files
Usually picked up downloading cracks
Get a decent antivirus suite to protect your computer
A lot of them have a free 15 to 30 day period
Aug 20, 2008 | Intel Motherboard
I have an Emachine and the disk drive won't work a box pops up and says at the top RunDLL and inside it says Error loading C:Windows/system32/gzmrotate.dll
RunDll is a system file. Error loading C:Windows/System32 is also system files. Just do a repair---not a recovery. The repair option is after you have to hit F8 then choose "R" for repair. This should take care of it. If not it may be your hard drive in which case you would replace it and have to do a full reinstall.
Aug 10, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
