Question about TallyGenicom 2280 Matrix Printer
Tally 2280 printer givesw printhead hot error
When ever i start the printer it gives printhead hot error but it works
Wants one printer head tally 2280+ at lucknow please tell me dealer at lucknow
Posted on Jan 21, 2011
  • 3 Answers
Is it a + version, with an Ethernet board included? These were known to cause such errors, seamingly not related at all. Try replacing the Ethernet board, or at least pull t out and disable to try.
Posted on Jul 03, 2009
Hardware alarm -4045 +131
That error means the that Printhead is not where the printer expected it to be. Clean the emitter grid (under the Printhead) with a soft cloth and clean the sensor with canned air. If that does not clear it up it is normally the Main Board Assembly.
There is a T2280 and a T2280+ they take different Main Boards so make sure you get the right one.
T2280 MRP provides IT Parts Product Supplies and Services
T2280+ MRP provides IT Parts Product Supplies and Services
Aug 13, 2015 | Genicom Tally 2280-2t Dot Matrix Printer...
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
Hi my Tally printer giving an error Pw Sensor defekt plz advice me
You are seeing the "PW Sensor Defect Error" because the printer is detecting a fault with the Paper Width Sensor.
The Paper Width Sensor is located on the print head carriage and detects the paper edge to prevent printing on the platen.
You can check the follwoing;
  • Ensure the print head cable is not damaged and makes good contact with the printer and print head carriage
  • Ensure the Paper Width Sensor is connected correctly to the print head carriage assembly
  • It may be necessary to replace the Paper Width Sensor
Mar 09, 2011 | TallyGenicom 2280 Matrix Printer
AGA ERROR IN TALLY 2265
either your aga motor is bad or your board set is bad. Turn unit on watch the printhead while opening the cover. The printhead should move back and display "cover open". When you close cover the printhead should move closer to paper. If not bad aga motor or bad board set.
Dec 15, 2010 | Tally Dot Matrix T2265C Printer
Hai , i have tally 2280 sprintpro printer.now it
problem with aga gear open the printer & check the white gears situated left upper of aga motor .......
or
may be aga flag missing or misalinged
Jun 29, 2010 | Tally Matrix T2280 Printer
Our tally 2280 Dot matrix has an alarm code 025609413032 What causes this to be displayed on the 2280 screen.?
check out this FAQ page for the hardware alarm codes:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=295%3Ahardware-alarms&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 19, 2010 | TallyGenicom 2280 Matrix Printer
"check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
Printhead hot error on tally t2265 but all pins fire ok, just stops and gives error, printhead is cool to touch, after a few minutes it prints a line or two again. it does this immediately, not after a...
The problem is with the main board when it gets print head hot immediately. The power supply is still functional, but something on the main pcb portion causes it to give an immediate "Print Head Hot" alarm
Jul 22, 2008 | Office Equipment & Supplies
Tally 2280
It sounds like you may have a broken (or perhaps stuck) pin in the printhead. Check for missing dots in other letters also, or if printing a graphics object, again, a missing dot, consistent throughout the print. Other possible causes of a pin not being "fired", are a small break in the ribbon cable from the printhead to the control circuit. Look for a tiny crack or break in the ribbon, especially along the edge. Also, a defect in the electronics which control the printhead pins will cause this. If by chance the printhead is all gooped up with old ink, a pin might merely be stuck. I have taken printheads out of dot-matrix printers and soaked the pin area (area closest to the paper) in rubbing alcohol, or used Chemtronics cleaning chemicals to spray off the old sticky ink. Messy job: don't wear a clean white shirt! Lastly, if a pin is broken, either the printhead must be replaced, or sent in for repair, assuming repair centers still exist. In years gone by, I have sent in heads, and gotten them repaired successfully.
Apr 23, 2007 | Tally Matrix T2280 Printer
TallyGenicom 2280 Matrix Printer Logo
651 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
