Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp,hdtv,lcd> unable to watch a video
WE JUST GOT OUR SHARP HDTV,LCD AND we are TRYING TO CONNECT IT TO THE DVD PLAYER SO WE COULD WATCH A MOVIE BUT IT WOULD NOT WORK (NO SOUND/NO PICTURE). IS THERE SOMETHING TO ADJUST ON THE SETTING? WE TRIED EVERYTHING. PLS. HELP. THANKS!
  • Anonymous Mar 22, 2009
    I have gone through all of the input settings on the remote waiting awhile incase it was just slow to recognize it and it still will not recognize my dvd player.
  • 356 Answers
With the input button on the remote cycle through all inputs until you get the signal.
If this does not work let me know and we can look into your connection.
Lone99star.  Please rate this solution.
Posted on Feb 14, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
How do you connect the dvd so you can watch a movie?
be sure you have selected the proper input on your TV; looks like you have an option of 2 HDMI inputs on the back or 1 on the side; or 2 component inputs on the back
Nov 28, 2013 | LG 42LG30 42 in. LCD HDTV
Why does my tv black in and out when viewing a dvd?
IF it only does this when watching a DVD first hook the player to another set to see if same issue---if same you may have either a dirty or failing optical pickup unit in the player---dirty and it can be cleaned---bad and usually it is cheaper to replace the player.
Apr 21, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have picture but no sound when connected thru hdmi using a panasonic blue ray Dvd player. It is working fine with my 42 inches sharp lcd.
Be sure you are not trying to use 1080p/60 from your Blu-Ray player to your Toshiba. You should connect the player to the Sharp, then set the output to 1080i... then move it over to the Toshiba.
Mar 14, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Sound is okay watching tv on hdtv - but crackles with dvd playing
If your DVD player supports HDMI or OPTICAL / DIGITAL audio then I would take a look at swapping to those type of connection first. This would help eliminate bad cords / connectors / electrical interference from other sources
Your TV has two hdmi inputs and optical so you have a choice
Aug 08, 2009 | Vizio GV42L 42 in. LCD Television
TV going black still hear sound
I suspect if you are using the DVD to play via a Scart connector , then the problem is simply that the Scart cable has became a bit slack. Try taking the Scart out of the rear connections from the DVD & the TV & then just pushing them back in again to make sure they have a good contact.
Apr 04, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Jul 31, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
HDTV Sharp- Input select to watch Cable tv
On the sharp remote you will find an input button. You depress the input button and a menu will appear and highlight the input you are presently on. Hit the input button again to select the next input. If you wait to long to depress the input button it will not work and you have to begin again. This unit will only hightlight inputs have a component hooked to that input.
Feb 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos set up
wild shipping my sharp aquos 42 inch it get a crack in the screen can i buy just a screen for it and what's the cost for it
Dec 15, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
98 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
