Question about Fisher and Paykel GWL11 Top Load Washer
Washing machine wont start
Not sure about the model number, but it is about 10 years old and a 7.5kg model...the machine filled completely and then just died..turning the unit on and off does nothing..the lights come on as normal but as i press start it does nothing..any ideas?
  • theo791 Feb 14, 2009
    Did it take you long to come up with that answer? Same could be said about your attitude!
  • 21 Answers
GET a NEW ONE
Posted on Feb 14, 2009
My dial wont move to different settings and on the wash its on it wont fill
If your dial will not turn, there should be one of two things wrong with it.
1) If your machine is over 10 years old, it is likely the timer/control is broken ( as in: worn out), and will need replacement.
2) If it is less than 10 years old, it could also be the plastic ears of the timer/control have broken off and again, that unit must be replaced.
(About 10 years ago, the timer/control began to be changed from a metal housing to a plastic housing on some machines.)
God bless your efforts to fix it.
Dec 15, 2017 | Washing Machines
The tub starts to fill then it shuts off wont complete wash cycle
Depending on the model, it could be a few things:
Fill level sensor
door switch
timer
control board
The model really matters, as Maytag has been making washers for 70 years. uploadserror please enter an image url (gif, jpg, png).
Dec 09, 2014 | Maytag Washing Machines
After 4 years our washer has begun growling and grinding when water fills atbthe beginning of a new cycle. It lasts for 10 or 15 seconds and then goes away. The machine then completes the job. Is some part...
If it is making the noise just as it is filling then you need to replace the "water inlet valve". If you can post your model number I can direct you to the part you need.
Aug 03, 2011 | Kenmore Washing Machines
Washer doesn't stay running. filled with water, then shut down then filled some more and now stuck doing nothing. If push start button if runs for about 5 seconds then shuts off. 10 years old.
For being 10 years old...I'd say R.I.P Neptune. A 10-year-old dryer is going to cost you more in repairs than the cost of a new machine! And even if it is cheap enough to fix, the parts may be no longer available. I used to work at the Harrisburg PA Sears Parts/Service Center...trust me...I know.
Jan 29, 2010 | Maytag Neptune MAH6500A Front Load Washer
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
80 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
