Question about Saeco Aroma Espresso Machine
What is the priming?
Hi, I have a Saeco Odea Giro for  few months now. Unfortunalty there is no manual in my native language, Romanian so I followed the instructions for installing, cleaning & usage. But today something strange happened: the right exclamation mark stays red and flashes. I red in the book that I have to "prime the water circuit". Can someone explain me what that is?  I know this might sound stupid, but in all the dictionaries "prime" is being defined as "blossoming" so I don't really understand what I must do.
Many thanks!
  • Anonymous Mar 20, 2014
    How do I prime the circuit? The warning light, the water light and the brewing light are all flashing and the instructions tells me to prime the circuit but doesn't tell how todo it. Thanks
  • 24 Answers
Prime refers to priming the pump. The error message means that there is air in the system which is preventing the pump from pumping water. To correct this, fill the tank with water, press the water button on the right side, and turn the water/steam knob to open. Allow the water to flow until the stream is steady. Press the water button again and your problem should be fixed
Posted on Feb 14, 2009
How to open the saeco odea
After descaling and rinsing, you need to hold the hot water button for 6 seconds to reset the descaling indicator.
Mar 26, 2013 | Saeco Odea Giro Plus Coffee Maker
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
How do I prime the saeco odea giro plus?
Hi, open the steam/hotwater outlet while its heating. It allows the air to release and water to fill the void. Dazza. Enjoy your coffee
Oct 23, 2011 | Saeco Odea Giro Plus Coffee Maker
Hi, I've got a saeco odea giro plus. 3 weeks old, the descaling ight came on. I followed descaling steps in manual. rinsed off brew group and place it back in unit. now the system will prime, grind, I...
Look at the brewing group where the top strainer is. The small holes are blocked with coffee. The water can not pass through them.
You will need to unfold the two screws at the top and then remove the strainer, grow and clean it and clean it if the holes are blocked.
Do this only
Apr 29, 2017 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
We have an Odea Giro in the office. When we got it I remember the coffee tasted amazing. After few months the taste started to decline and after some time we stopped to use it altogether. I wanted to...
you are supposed to go through the "before first use" instructions....which include filling the resevoir with water and brewing only water until its all gone. then start using the machine normally...remembering that the machine takes a few brew cycles to adjust properly to the coffee being used (this assuming this is the giro plus model which has the feature-"aroma something or other...)
also, descaling would help and removing the brew group and rinsing it out...
Nov 23, 2010 | Saeco Odea Giro Plus Coffee Maker
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Jan 06, 2010 | Saeco Odea Giro Plus Coffee Maker
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
Coffee Makers & Espresso Machines Logo
1,629 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
