Question about ASUS A7N8X-X Motherboard
Beeps the motherboard beeps for a wile and then shuts it self down
    Sergeant:
    Champion:
  • 206 Answers
You also might want to check the heat sink and fan. The shutting down part usaully indecates a heat issue with the cpu. The BIOS shuts everything down when it gets hot to prevent it from burning up (hopefully)
Les
Posted on Jun 27, 2009
    President:
  • 1,179 Answers
Depending on the beep code it could be saying there is a RAM problem or a video card problem. Check video card first & see if reseating it corrects the problem. If not try reseating the RAM. Also make sure the RAM installed is compatible with the board you are using. Have you upgraded the cpu? If so you may have used an incompatible chip or do not have it fully seated. These are the first things to check. Hope this helps.
Posted on Feb 14, 2009
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
Computer was shut down abnormally following a power failure in a thunder storm. No apparent physical damage to machine but will not reboot. Machine gives single long beeps at 6 second intervals. BIOS is...
take out the processor chip and clock battery along with the ram while it is disconnected from the wall outlet and wait about 5 mins. after you put it back together, if the problem persists the processor might need to be replaced or the entire motherboard its self.
Jun 28, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
Beeps on startup but no video and continues to have long beeps with no video
Check the the cpu, ram and video card are seated properly. If they all are, then the board is defective and will need to be replaced.
Mar 05, 2011 | Abit NF8-V Motherboard
I used a vacume to clean my computer now when i press the power on the fan spins non-stop wile a steady beep every five seconds without showing anything on my monitor
This means the machine is not making it past the POST or power on self test. This is bad. This means it could be your RAM, your processor, your video card, or something isn't properly seated or connected. Please take your computer to a professional tech who is A+ certified (try to avoid the generic best buy type fix it shops for something like this). Please never try to vacuum your computer. If it needs cleaning please, please use compressed air and blow out any dust/debris in a controlled manner. Thank you and I'm sorry I don't have better news for you.
Jan 04, 2011 | ASUS Computers & Internet
Door was opened at beginning of self cleaning sequence.. locking mech is still stuck
hold button for light down and hold it wile pushing put in clean and wait till it starts then push stop or cancel and wait til cleared dont let go of light switch till done.if don't work have someone hold down the switch wile you turn off the breaker for 2 min
Dec 24, 2009 | Frigidaire Ovens
Laptop shuts down automatically and emits a beeping sound
Yes this is for the memory problem...Try to change the RAM...
Oct 20, 2009 | Fujitsu Siemens LIFEBOOK P1510D Tablet PC
I have a DFI AM75-TC motherboard, 3beeps, no video
Hi richardbyers, three short beeps means there is a problem with your memory. (Base 64K memory failure). Unplug the power from the PC. Open the case & touch the bare metal on the case to discharge your self.
Remove the memory & reseat it. Leave the case opened & re-connect the power cord & try booting again. If you still hear three short beeps, shut the system down again as mentioned above. Gather some house hold alcohol & a couple cotton swabs. Drip a drop or two onto a cotton tip & wipe the memory's contacts, both sides & do not touch the contacts with your fingers during re-install or cleaning. Blow the memory slots out with canned air or use a clean paint brush. Insert the memory again & connect the power cord. Boot the PC. Try this first. If everything works out than good. If the problem does not clear its self let me know.
Good luck richardbyers!
Mike
Jan 06, 2009 | DFI AM75-TC Motherboard
Abit IC7 motherboard
I wasn't supposed to post it as a clrification.
Jun 15, 2008 | Abit IC7 Motherboard
ASUS A7N8X-X Motherboard Logo
122 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Tony
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
