Question about Technics SL-1210M5G Turntable
Stiff Pitch Adjustment
My warranty has just expired and now suddenly my pitch adjustment is very stiff when I try to move it. I opened up the top of it and saw that there is some grease showing around the top as if it leaked. I opened up my other turntable and did not see any grease. Is there a way to fix that by taking it apart and removing the adjustment? Or will I have to send it in to get it repaired?
  • 515 Answers
What did you open up? The top of what? If you could be specific, I can direct you.
If your pitch is stiff, try spraying some contact cleaner or similar - DO NOT USE WD40. Use an electrical contact cleaning solution, such as CAIG DEOXIT or CAIG FADERLUBE both work very well, and are good for electronic contacts.
If this does not work, then maybe the pitch control knob/shaft is slightly bent? Any physical damage?
Other than that, there isn't a whole lot you can do, unless you replace the pitch control - Technics Pitch Control.
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 05, 2009
I have have high pitch wind noise from fan clutch after replacement is it normal on new fan clutch
Fan clutches are stiff and loud till vehicle runs a bit, as fan clutch mechanism warms up drag on clutch mechanism releases pressure and will free wheel.
Do not mistaken this with, when engine hot, clutch engages to help cooling system which is normal.
Feb 17, 2015 | 1997 Ford F150 Regular Cab
Adjust pitch
Register (free) at Vinyl Engine and download the service manual. The adjustment you need to do seems fairly simple. You will need a turntable strobe disk to get the the speed right, unless you have perfect pitch.
Jun 19, 2014 | Denon DP-29F Turntable
Adjust pitch not working on PS T1 Sony
Try looking underneath the turntable. There might be two speed presets one for 45 and one for 33. They could be covered up by stickers.
Jun 04, 2014 | Sony Audio Players & Recorders
I got a 98 triumph thunderbird 900. When I going at a speed let say 45 for a few min it bucks. When I am on the gas I don't feel it. I know the chain has a stiff link in it. But don't think that...
stiff link indicates badly worn sprockets/worn chain that is throwing out the pitch between the chain and the sprockets
what you feel is when the pitch gets out enough for the tooth to try to pick up the link
take the chain off and test for wear holding a section between the hands and seeing how far you can bend it side ways
any more than 1/2 link in a foot span is a worn chain
next check the sprockets and if there is not a bulge 1/2 way up the tooth ( goes straight to a point ) replace the sprockets as well
Jan 07, 2018 | Motorcycles
Pitch bend issues
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
Oct 17, 2017 | Akai Ewi4000s Electronic Wind Instrument
Squeaking when starting up.
If this is a high pitched squealing sound, then check the condition and adjustment of your engine's rubber drive belts.
If these have become stiff or worn, then they can begin to cause this noise, especially when starting from cold.
Nov 16, 2012 | 1994 Isuzu Rodeo
I have a Realistic LAB 2100 Linear Tracking Automatic Turntable. When the arm is drawn closer to the center of the record, the motor that is supposed to move the arm into a perpendicular position with the...
It seems like you need to adjust the pitch control. Try looking at the platter strobe light and seeing if it is at the correct speed. If not adjust the pitch control until you can see the dots align. As for the not returning, your automatic motor may be busted.
May 15, 2011 | Radio Shack Audio Players & Recorders
I have cleaned the worm and Gear segment for blade raising mechanism on my 66 and it still binds and is stiff. What do I do next?
Try lubricating with silicone spray. I use it for just such things, and I'm happy with how it works. Also, clean and lubricate the lock on the elevation control.
Jan 29, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Platter problem
THE PITCH slider or the variable resistor could have gone faulty. A new pitch is only $25 i think. They may need to salvage the pcb from your old one as technics no longer manufacters them. I've never seen the pitch led stay on lock when the actual pitch is not at zero. Hopefully the pitch did not short out the brake or the variable resistors on the motor's circuitboard.
keep me poted.
Oct 25, 2007 | Technics SL-1210 Turntable
Technics SL-1210M5G Turntable Logo
343 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
