Question about Microsoft Windows XP Professional
Windows Startup Error csrss.exe
When ever i start up my computer and log in i get this message:
-->Windows Cannot find 'C:\WINDOWS\Config\csrss.exe'. Make sure you typed the name correctly, and then try again. To search for a file, click Start button, and then click Search.<--
Please help me with this.
I want anything for a solution except re-install XP.
  • sidspyker Feb 14, 2009
    I am using XP and this error pop-ups whenever i start up my windows
    and when i search for csrss.exe,i get two results
    on is System32 and the other one in
    WINDOWS\ServicePackFiles\i386
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Do a file search for csrss.exe and comment back the results.
    Are you using XP?
  • 23 Answers
Okay, we are going to try two things. If the first don't work go to the second.
1) First perform a search on your computer for the 'csrss.exe' file. If found, copy it and then paste it into your C:\windows\system32 folder.
That should do it.
2) If that don't do it or your search can't find it, then perform the following;
To scan and verify the versions of all the system files that Windows File Protection protects, use the System File Checker (Sfc.exe) tool together with the /scannow parameter. If the SFC.exe tool detects that such a file was overwritten, the SFC.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows installation source files, and then replaces the incorrect file.
To run SFC, please follow these steps:
1. Click on Start > Run command prompt
2. Type SFC /scannow, and then press ENTER
Note: You may be asked for inset OS CD.
3. After finishing SFC, you may run CHKDSK C: /R in the Run command prompt as well.
Posted on Feb 14, 2009
    Problem Solver:
  • 16 Answers
Here is a post that might help:
The csrss.exe file should be in the C:\windows\system32" directory, not config directory. Verify this: The legitimate csrss.exe is part of the Microsoft client server software and is a very important part of the system which should not be removed.
One way to determine if csrss.exe is a legitimate file besides looking at the date modified is to right click on csrss.exe inside Task Manager and attempt to end process. Because csrss is a critical file, Microsoft should inform you with a message that csrss.exe is a critical system process and end it is not possible.
If you do not receive this message when attempting to end the csrss.exe process, then it may indeed be a virus. If you decide to terminate the csrss.exe process, make sure any applications are shutdown (such as word, etc) and that you have a backup of your data.
Shut off system restore and run a virus scan on your system. Afterwards, restart system restore and check again.
Error message 0xc000021a
Winlogon.exe
Winlogon.exe is a part of Windows Login System. As suggested by its name, this process is responsible for handling login and logout procedures on your computer. Primarily though, it is concerned with the following functions:
  • Managing secure attention sequence
  • Loading user profile
  • Locking the system while Screen Saver is activated
  • Providing easy access to Windows station and desktop
Csrss.exe
Csrss.exe is a user-mode program belonging to the Microsoft Client/Server Runtime Server Subsystem. It is a critical piece of software responsible for managing threads and creating console windows. Furthermore, it is also thrown the crucial duty of controlling operations of the Win32 subsystem not belonging to the kernel mode.
A STOP 0xC000021A message is generated when either of these processes fails to execute. Upon detecting this bizarre dilemma, Windows NT kernel halts the system and raises the BSOD error. Following is a list of common causes leading to the failure:
  • Mismatched system files have been installed
  • A Service Pack installation has failed
  • Incompatible third-party software has been added
  • Unsupported drivers are housed in the system
Jul 20, 2014 | Gateway NE56R10u Laptop Intel Celeron...
More than 1 csrss.exe
Start a command-line prompt (Windows-Key-plus-R-key).
Enter 'CD \' and press ENTER.
Enter 'DIR /S /A /P CSRSS.EXE*' and press ENTER.
You could have a computer-virus (in some folder "other" than WINDOWS\SYSTEM32) that has the same filename.
Jan 19, 2014 | Microsoft Windows 7 Professional 32 bit...
Csrss.exe
Not a lot of information to go by, but it looks like you have a trojan virus.
There should only be one copy of csrss.exe running per user logged into the system.
I've attached a possible solution, but I recommend you get a full virus scan by removing the hard drive and attaching it to another system that has the scanning software installed.
http://www.ehow.com/how_6589718_remove-csrss-exe.html
Jan 16, 2014 | Microsoft Windows 7 Professional Service...
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
Windows canot find windows system32 drivers prgds exe
Are you getting this error message on startup/login? Does it prevent you from logging in? If so then try starting in Safe mode. See http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode for instruction on doing this in Windows 7.
What version of WIndows are you running?
Sep 07, 2011 | Dell Computers & Internet
Hi, i have a dell vostro 1520 laptop when loading up it has the windows xp screen then it goes to a blue screen with: STOP: c000021a {Fatal System Error} The windows logon process terminated...
This Solution is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact Technical Support.
When you use a server or a workstation that is running one of the operating systems that is listed in the "Applies to" section, you may receive the following error message: STOP: c000021a {Fatal System Error}
The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000)
The system has been shutdown. Note The parameters in parentheses are specific to your computer configuration and may be different for each occurrence. uparrow.gifBack to the top CAUSE The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. Wh... loadTOCNode(1, 'cause'); The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
RESOLUTION To troubleshoot this problem, you must determine which of these processes faile... loadTOCNode(1, 'resolution'); To troubleshoot this problem, you must determine which of these processes failed and why.
To determine which process failed, register Dr. Watson as the default system debugger (if it is not already the default debugger). Dr. Watson for Windows NT logs diagnostic information about process failures to a log file (Drwtsn32.log). Also, you can configure this program to produce memory dump files of failed processes that you can analyze in a debugger to determine why a process fails.
To set up Dr. Watson to trap user-mode program errors, follow these steps:
  1. At a command prompt, type System Root\System32\Drwtsn32.exe -I, and then press ENTER.
    This command configures Dr. Watson as the default system debugger.
  2. At a command prompt, type System Root\System32\Drwtsn32.exe, and then select the following options: Append to existing log file
    Create crash dump
    Visual Notification
  3. After the computer restarts from the STOP 0xC000021A error, run Dr. Watson (Drwtsn32.exe).
  4. View the Dr. Watson log to determine what user mode process may be causing the problem.
  5. If the Dr. Watson log does not contain sufficient information to determine the cause of the problem, analyze the User.dmp file to determine the cause of the STOP 0xC000021A error.
    If Dr. Watson did not create a User.dmp file for either Winlogon.exe or Csrss.exe, you may have to use a different tool to generate a memory dump file of the process that fails. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 241215 (http://support.microsoft.com/kb/241215/ ) How to use the Userdump.exe tool to create a dump file Note Follow the instructions in the Knowledge Base article to troubleshoot a process that shuts down with an exception. While you follow these instructions, monitor the following processes to troubleshoot the STOP 0xC000021A error:
    • Winlogon.exe
    • Csrss.exe
    Note Most STOP 0xC000021A errors occur because Winlogon.exe fails. This typically occurs because of a faulty third-party Graphical Identification and Authentication (GINA) DLL. The GINA is a replaceable DLL component that Winlogon.exe loads. The GINA implements the authentication policy of the interactive logon model. The GINA performs all identification and authentication user interactions.
It is very common for certain types of remote control software to replace the default Windows GINA DLL (Msgina.dll). Therefore, a good first step is to examine the system to see if it has a third-party GINA DLL. To do this, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Value = GinaDLL REG_SZ
  • If the Gina DLL value is present and if it is anything other than Msgina.dll, it probably means that a third-party product has changed this value.
  • If this value is not present, the system uses Msgina.dll as the default GINA DLL.
If this error first occurred after the installation of a new or updated device driver, system service, or third-party program, the new software should be removed or disabled. Contact the manufacturer of the software to see if an update is available. For more information about hardware and software vendor contact information, visit the following Microsoft Web site: - http://support.microsoft.com/gp/vendors (http://support.microsoft.com/gp/vendors) Last known good configuration loadTOCNode(3, 'resolution'); If the previous steps in this article do not resolve the problem, start the computer by using the last known good configuration. To start the computer by using the last known good configuration, follow these steps:Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Click Start, and then click Shut Down.
  2. Click Restart, and then click OK.
  3. Press F8 at the indicated time:
    • For an x86-based computer: When a screen of text appears and then disappears , press F8. (The screen of text may include a memory test, lines about the BIOS, and other lines.) There may also be a prompt that tells you when to press F8.
    • For an Itanium architecture-based computer: After you make your selection from the boot menu, press F8. There may be a prompt that tells you when to press F8.
  4. Use the arrow keys to select Last Known Good Configuration, and then press ENTER.
    NUM LOCK must be off before the arrow keys on the numeric keypad will function.
  5. Use the arrow keys to highlight an operating system, and then press ENTER.
Notes
  • Choosing the Last Known Good Configuration startup option provides a way to recover from problems such as a newly added driver that may be incorrect for your hardware. However, it does not solve problems that are caused by corrupted or missing drivers or files.
  • When you choose the Last Known Good Configuration option, only the information in registry key HKLM\System\CurrentControlSet is restored. Any changes you have made in other registry keys remain.
Jan 18, 2011 | Dell Vostro 1510 Laptop Computer PC...
Windows can not find csrcs.exe
Hi
Thank you for your query
You have a virus on your PC
Please carry out the following steps to remove it, please do not confuse csrcs for csrss which is a valid windows file
1. Scan the system with a good and updated Anti Virus.
2. Open Task Manager, locate this exe (csrcs.exe or csrsc.exe but not csrss.exe), and kill the process.
3. Now type msconfig in the Run box, and then go to startup tab.
4. Locate this exe file, if any, and then remove it from there as well.
5. Now search the file in the C: drive.
6. Permanently delete the file (csrcs.exe or csrsc.exe only) from the computer.
7. Reboot the PC for changes to take place.
UPDATE
After doing the above steps, you need to clean the registry as well.
  1. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon\
  2. On the right side, there is a key named “Shell”, it may be having a value “explorer.exe csrcs.exe”. Just modify it to delete the csrcs.exe from it (not explorer.exe). Restart the computer
Please finally re do a virus scan to ensure it has gone
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 16, 2010 | HP Computers & Internet
Csrss.exe encountered a problem and needed to close. This error i am facing when i logged as admin to Win xp sp2 O.S
Hi swancul,
Try the following link and follow the directions on that page to download, install, and run free software to fix this problem. Hope this helps! Hal
http://www.exenerd.com/exe.php?seed=Csrss.exe
Jun 03, 2009 | Microsoft Windows XP Professional SP2
Reset secure clock
Cause and Solution to Secure Clock Error
First thing you need to do is open up your task manager by clicking control alt delete.
Select the tab "processes." In the process tab you will see a list of programs that are currently running, if you locate a file called csrss.exe it could be a trojan virus that is blocking your subscription music from communicating with your computer properly. It also effects a lot other things including hardware, personal information, security, etc. but for this post we will keep it specificly on the secure clock error. This csrss.exe trojan/virus causes your computer's internal system to not function correctly including the secure clock.
NOW WAIT! There are two different csrss.exe files, a good one and a bad/trojan one. All windows computers have a csrss.exe file on them and this "good" csrss.exe file is need in order for your computer to run propertly so don't do anything with it until you determine if you have the "good" one or the "bad" one.
You must first determine whether the csrss.exe file that is running on your computer is the "good" one that ships with the computer (inside your systems32 folder) or whether you have the trojan/virus csrss.exe file infecting your computer and secure clock.
Since the systems32 program and the Trojan/virus are both name csrss.exe you must run a quick test to see if you have the bad one or the good one or both.
First locate all fo the csrss.exe files inside your "processes" tab inside task manager (you may have more then one). The way to tell if you have the trojan or "bad" csrss.exe is by right clicking on it and selecting "end task." If you have the "good" one then you should get a windows pop up message. If you you get the windows pop up message, do NOT "end" the task, just ex out or cancel out of it. You do not want to end the "good" csrss.exe file because it is needed in order for your computer to work properly. If you "end task" on the good csrss.exe file then your computer will instantly crash (since it is needed to run).
If when you right click on the csrss.exe file and select "end task" you do NOT get a windows pop up then you may very likely have the csrss.exe trojan virus. In addition to the right click test you may want to simply look at where this file is located. If it is in your systems folder it is the good one, if it is anywhere else it is propably the bad one.
The trojan/virsu version of this csrss.exe file interferes with many of the communication hardware,drivers, software, security, etc., including rhapsody and will prompt this secure clock error message.
The only way to remove this csrss.exe trojan is to perform a system recovery on your computer returning your computer back to the original manufacturers settings. There is no way to clean, delete or remove this file trojan, you must perform a complete clean of your system by doing a system recover.
If you cannont determine whether your csrss.exe file are good one or bad ones simply back up your files and software and do a system recovery anyway, your rhapsody and mp3 player will then work fine.
May 21, 2009 | Coby MP-705 Digital Media Player
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Dec 02, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
3,380 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
