Question about Samsung SGH-C166 Cellular Phone
NETWORK LIMETED SERVICE. SIM(AIRTEL) OK. PHNESET MANY MORE TIME RESTATERD! SO PLEASE SOLVED THIS PROBLUM. THANKS.
  • 126 Answers
Actually its te problem with network . your phone is not able to scan network or the sim is damaged.
pls rate me thankyou
Posted on Feb 14, 2009
Insert sim card is found in low signal
First:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Second:
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Jan 12, 2013 | Samsung GT C5130 Mobile
My Airtel Mobile No is 9945623455 Please send My PUK Code to another number 7760967641... I Wan't PUK for My Airtel No 9945623455
A request for a PUK code ("Personal Unlocking Key") will appear on your phone if your SIM card PIN code is entered 3 consecutive times incorrectly.
Your SIM card will then become "PUKed" or Blocked. This is a security measure to protect your service.
You need to call the Customer Service department of your cell phone provider and they will give you the PUK code which will unblock your SIM card.
Nov 19, 2010 | Nokia 1650 Cell Phone
Airtel sim not work
There are various network specification for each operators like airtel, BSNL, etc
Nokia 3110 supports GSM 900 / 1800 / 1900 so Airtel SIM card should work in your mobile.
Try using some other airtel sim cards and some other sim cards from other vendors as well. SOme times the problem with network chip may also cause this problem. so in such case, you can approach nokia service center to claim under warranty.
Please rate the solution
Thanks
Sep 18, 2010 | Nokia 3110 Cellular Phone
Signal problem
Dear customer
I will get vary happy to help u. If u are a Technician then open ur mobile handset by T-6 screw driver and firstly wash ur network antina and IC areas by a toothbrash with PCB cleaner.Check the network connecter make a jumper from network connecter to connecter pins by micro soldering IRON and give some hot air to network IC with pest.If u are not a technician then its better to go ur nearest NOKIA care center.If u are saticfied withmy information then please vote me. Thank you for your visit.
May 24, 2010 | Nokia 6300 Cellular Phone
Network problem using airtel sim in Iphone 3g
My problem is quite similar... My iphone works in some parts of delhi and it shows no service for other parts of delhi... If i use idea sim on my iphone, it works absolutely fine... and if i use my airtel sim on any other phone then also things appear ok..
any ideas?
Jan 30, 2010 | Cell Phones
SIM lock only AIRTEL SIM works
you may have locked your sym card. if you did, your phone would prompt you for a password when it turns on, just to access the network. try some basic codes like 0000 or 1234. these are most likely the factory defaults.
Mar 25, 2009 | HTC Touch P3450 Smartphone
Searh of airtel puk number
it will ask for the PUK code when you try inserting the wrong pin
for 3 times ...
so to get the PUK code follow these steps:
1. call to your network provider s customer care from some of your friends number of the same network ...
tell your number & ask them for the PUK code..
2. they may ask you the details of sim like in whose name it is etc..
answer that ...
3. after that they will provide you the PUK code note it down
4. enter the noted PUK number to your cell ...
5. your sim will get unlocked ....
caution: if you try inserting the wrong PUK codes for more than 5 or 10 times it will completely block the sim after that you must contact the network provider s shoppe only to get it unlocked ..
remember this ...
this solves your problem ...
Sep 05, 2008 | Nokia 3315 Cellular Phone
Samsung SGH-C166 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
