Question about ASUS MB M3A78-EMH HDMI RT Motherboard
Extra wire /fan 3pin hole 1wire where to plug in X 2 fans
Asus M3A78EM,M.B. fans for cpu cooling have each got extra yellow wire,where do I conect to M.B. Can't find pins.I hope someone isa smarter than me ouitr there,an d can I hook up 2 fans to same hookup, or is therew 2cnections or do I need an adapter.If it;sspeeded up or sloweddown by voltage is it posible to connect both wires to same hookup.Trying to solve any mixups beforhand
  • 2 more comments
  • dave21812 Feb 14, 2009
    The fan has a 4pin conector that goes to the power unit. the large type still being used on H.D. and dvd units ,cd units,but the wire I'm talking about is a seperate 5th wire tha only uses 1 of the three holes. Holding the white plug down flat with the 2 guides up ,as it will only go on one way ,it's the left side.Now the cpu socket has a four pin receptacle.My plg will fit on as the peice that goes between the two guides on the M.B. is ofside and the man. labels that pin cpu fan in. Is that pin a,the sensor pin.Hate to blow M.B. by a simple mistake.I only do knowingly.No guess.
    The receptacle on M.B. is for cpu labeled as such left to right cpu fan pwm,cpu fan in,cpu fan power,gnd.My 3 pin connector with one wire fits on 2nd,3rd,4th.and the only wire to that conector contacts,cpu fan in .fit's perfectly as I said guide is offset. My apologies to everyone who tried to help,for my ununderstandable discription. I think I solved it my6self but would like absoulute info.Again ,blow M.B. for something so simple. I would advise everyone to be as safe as I am.You learn by your mistakes,but rather it be a mental mistake.Know,Not think you know.affirmation please. dave21
  • dave21812 Feb 15, 2009
    I am using an after market heat sink.It uses2 120mmfans.They use the old style large 4 prong connectors tha come from the power supply.The M.B. has a 4 prong setup .A 5th wire attached to a 3 prong plug.It fits offcenter on the 4prong setup .The M.B. doesn't tell you which prong is for the sensor. There is a small 4 prong receptacle on the M.B.When you plug the fan's to the large connectors from the power unit it's cofusing about what to do with 5th wiremounted on a small 3 pron plug and the manual doesn't tell that you plag the 3 prong on the 4prong and that it will fit beacause of the offset sytem the wire receptacle in place.but it's a perfect fiit. Is the cpu fan in prong for the sensor.Asus does'nt isn't clear about what prong is for what .Can someone tell me if I'm right.dave21
    President:
  • 1,901 Answers
Dave,
Your motherboard has a 4 pin connector for the CPU fan AND a 3 pin chassis fan connector.
Do you have the manual for the motherboard?
On page 1-8 the MB layout shows a 4-pin CPU connector about 1/2 inch behind the ethernet/lan connector. It should be screened on the MB as CPU_FAN.
The connector for the chassis fan is in the upper right of the board, just above and to the right of the RAM slot furthest to the right. It should be screened CHA_FAN on the MB.
If you do not have a manual, comment back and I can lead you there on the Asus support site.
Good luck and thanks for using Fixya.
Posted on Feb 14, 2009
  • Wayne Mineard
    Wayne Mineard Feb 15, 2009
    I am confused why you would rate this as Inapproprite. You asked if you could connect 2 fans and where the pins were. I told you. I know the pinouts. They are on page 1-11 of the manual. I have the layout of your MB.
    Sorry, but your Inappropriate rating is Inappropriate IMO.
    Have a nice day, nonetheless.
    President:
  • 1,179 Answers
If your cpu fan has a 4 pin connector & your mb has a 3 pin you can still use it. Just leave one pin exposed. The extra pin is for a speed control sensor that not all mb's support. The chassis fan has a different connector on the board marked "cha fan". This one is a 3 pin connector. Most of the asus boards have 1 of these. If you wish to run more than one you can either buy a "y" adapter that allows you to connect 2 fans to 1, you could use an extra 4 pin molex to power an extra fan but that would give you no control over the fan, or you could buy a fan controller and hook all your extra fans to it. Hope this helps & please take a moment to rate my solution fixya. Thanks.
  • Roy Lonsinger
    Roy Lonsinger Feb 15, 2009
    Do you actually think I would still help after you gave a terrible rating for the correct answer to your original problem? I'm done.
Asus laptop randomly shuts down
Possibly overheating. I would check the fan and airways are free from fluff.
Oct 06, 2015 | ASUS Computers & Internet
How do I find a manual for the ULT40278. I'm trying to figure out you would connect 2 fans when some motherboards have only one fan connection?
Motherboard fan connectors typically use a small 3-pin which looks like this: zero_awake.jpg
the left connector is a female connection (the side with 3 holes) the middle and right are male connections, has 3 metal pins:
  • Black: GND (ground)
  • Red: +12VDC or +5VDC (12V or 5V DC - direct current)
  • Yellow: Tachometer signal (used to read fan speeds)
NOTE: Wire color may vary, and some fans or motherboards may control fan-speed.
Some fans use a 4-pin connection, which is generally a CPU fan connector but not always:
This pictures a 4-pin connection, but may look different from other 4-pin connections because the wires are covered in a black sleeve, which keeps them safe from harm and to reduce potential negative affects on airflow created when there are lots of loose wires inside a computer case.
This photo shows a 4-pin connection attached to a motherboard next to a 3-pin connection in a motherboard. While it is not recommended in the case of the CPU's fan, in the case of other internal case fans with a 4-pin connection, it is possible to plug them into a 3-pin connector of the motherboard, but the ability to control fan speed, which is controlled in the 4th pin will be lost.
Though sometimes computers have a way of controlling fan speed on a 3-pin or 4-pin connection even without the 4th pin, such *** voltage regulation and reading tach. feedback. These things are typically things a general user doesn't need to worry about unless their computer is running particularly hot and causing trouble.
In which case, it might be worth investing some money in a fan controller, which takes a power connection, several fan connections (varies based on the controller you get) and gives you the ability to control fan speed externally on your computer case. My controller has nice dial knobs, though some "fancy" controllers have a display and up and down buttons. (Fan controllers would be at your own discretion in terms of price, you can get them cheap all the way up to seemingly ridiculous expensive)
In the event of not having enough 3pin or 4pin connections on a motherboard, it is still possible to add case fans by way of 4pin molex connections:
A female molex connection
A male molex connection
Some case fans run exclusively through these connectors, others have a combination of a 3pin (or 4pin possibly, though I've never seen this combination) and a 4pin molex connector. In this case, the molex connector can connect directly to a cord from the power supply and run the fan. It is possible to run case fans without having them connect to the motherboard at all! Which makes it possible to connect more fans, with less available connections for your fans on your motherboard.
If a fan is a certain connection (any of the 3) and you need to convert it, for example:
  • a 3pin to a 4pin molex because your motherboard doesn't have enough 3pin connectors for all your fans,
adapters are available to change one type of connection to another, at many online retailers (such as newegg.com, amazon.com, or other electronic supply retailers) and some retail stores, Best buy might have something, though you'd have a safer bet at a store like Micro Center which is more specialized for PC building or an alternative PC/electronic store.
To ensure you solve your problem, just be sure to familiarize yourself with the motherboard you are planning on buying (or have) and the fans you plan to have inside your computer. It can be a bit more work to check the specs on the fans and motherboards, but a little work saves hours of headache later.
Nov 03, 2010 | Ultra Products Ultra ULT40278 XT MicroATX...
Can not find PSU for ASUSP$B266 withA2542 3 pin connect. for CH_F
I think you are a bit confused here. Ther MoBo CH_FAN connector is an output for a Chassis Fan and does not need a supply from the PSU. It is dfor use if you wish to connect a fan to the casing to provide extra cooling and for the fan speed to be reported in the bios..
Apr 08, 2010 | ASUS Computers & Internet
Exchange a cpu fan connector
You can connect it red to red; black to black; and yellow
to white. That's it. Hope this will help you.
Dec 12, 2009 | R.A.M. Computers 486 CPU COOLING FAN WITH...
I.ve changed my motherboard and no longer have a 3 pin connection for the case fan on the motherboard. I know that + goes to yellow and - goes to black but where does the sensor wire go?
Hi:
An option for you is to just purchase a cheap adapter to plug your case fan into a unused power supply plug, such as one that plugs into a hard drive or optical drive.
Dec 11, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
CPU FAN ERROR PROBLEM
Check to make sure the CPU fan is plugged into the motherboard CPU fan power pins. Should be a 3pin port on the motherboard near the cpu with a white piece of plastic on the one side of it to show you are to plug in the cable correctly.
See if the fan spins at all on start up, or even when the computer is off, spin it with your finger and see if it gets hung up anywhere while it spins.
Mar 18, 2009 | Intel Motherboard
Intel Cpu Fan ReWiring
Here is the pinout for the wiring:
Pin Name Color 1 GND black 2 +12VDC yellow 3 Sense green 4 Control blue
In case this doesn't show...Black is Ground and Yellow is +12VDC.
Not sure if it will work w/o a Sense (Green) and Control (Blue) line though.
Jan 18, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
ASUS MB M3A78-EMH HDMI RT Motherboard Logo
584 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
