Eclipse Metrologic MS5145 Barcode Scanner Logo
Posted on Feb 14, 2009
DON'T KNOW HOW TO USE
Recently, i've bought a barcode scanner MS5145 (eclipse)..however, till noe, i still can't use it...i don't know how to use it...I have followed the instruction that asked me to connect to the ps-2 port of the keyboard port...then, i scan any of the label of barcode and press the button on the top of the scanner...it gave sounds of beep...then, how to see the output? using what format? please help me...i really don't know how to use it
  • Anonymous May 11, 2010
    What are you trying to do use it for? Why did you buy it?
    If you open a word doc or excel, you can scan a bar code and it will output there.
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Sep 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
21875
Points
15
Firstly you connect ps/2 scanner cable of ms5145 to computer.then connect keyboard to Scanner.You can open word and Scan any barcode it displays on screen
  • Anonymous Sep 05, 2009
1 Related Answer
Anonymous
  • 80 Answers
  • Posted on May 04, 2011
SOURCE: my mac is not recognizing
The scanner may need drivers, check for the brand name and go to their website to find the required drivers (if any.) If you already have drivers installed, try other USB ports.
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
1helpful
Drivers for ms5145
A standard PS2 to USB cable will not work with these scanners. You'll need to purchase cable # M009-3MA7C. They are expensive, so shop around for price.
My eclipse MS5145 is locked after the first scan , what can i do ?
connect the 2nd end of the scanner cable to a ps2 keyboard and reboot
Hi.....im using Eclipse Metrologic Instruments, model no.is MS5145 LS USB barcode scanner. now it is not working. whenever i tried to scan a barcode, it red light goes on continously. i also initialized it...
If the kit number : MK5145-71a48 that you referenced above is correct, your scanner is single ended keyboard wedge, not usb. You would need to order the correct cable : MX009-3ma7c from Honeywell to connect via usb.
My mac is not recognizing barcode reader honeywell MS5145
1helpful
2answers
Hanging problem
scan the exit code it will close your scanner and then scan the recall default code (4 times) then scan the ENTER code your problem will be solve
Eshwer
I ve lost my scanner drivers. How can i download?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=296
that is the best place to gte the drivers the filkes you need depend on the operating system and the configuration you have for example usb drivers.
Scanner won't scan red ribbon
metrologic ms3780 scanner only scans a few times then stops..when you remove it from the base and reinstall it it works afew times then stops again?
1helpful
2answers
Metrologic Keyboard Wedge Barcode Scanner (MS5145)
are you using usb keyboards if so set the scanners to stand alone keyboard wedge you will find this in the manual. if this is not the case it could be that the scanner is set for a different keyboard type just set the scanner for keyboard wedge emulation. hope this helps Pete
Top Eclipse Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Eclipse Computer and Internet Expert? Answer questions, earn points and help others
