Question about Toshiba Satellite Pro P300 Notebook
Scroll function on my Toshiba Satellite TouchPad isn't working
The TouchPad has been working fine since I purchased the laptop last February, but I think I unwittingly messed something up with a software update this week. The TouchPad allowed me to scroll by rubbing a finger up or down with the pointer displayed anywhere in the window, but this function isn't working. Now I can only scroll using the window scroll bar. When I open the pointing device tray icon in the taskbar, it offers options for a mouse rather than a TouchPad. Otherwise the pointer still works fine, but I would like to get the scroll function back.
Thanks,
Van
i have the same problem. it just started and i liked the feature. it would be nice if i could get it back.
Deb
    Problem Solver:
  • 16 Answers
I would go to this link and select your device and download the driver/software for your device. Try to reinstall the driver/software.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&cm_sp=Sitemap-_-Support-_-DriversDownloads
Note:
Fn-F9 is a hot key combination that will enable/disable the touchpad.
Posted on Feb 14, 2009
  • avevor Jan 31, 2011
    The software worked good for the touch pad scroll. thanks very much. thumbs up and keep the good work up
    President:
  • 2,976 Answers
In the mouse features window, click the advanced functions button. It gives you about 10 settings to set up for the touchpad.
2 Suggested Answers
johnnailed
  • 36 Answers
SOURCE: Scroll function on my Toshiba Satellite TouchPad isn't working
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
4s22
Posted on Jan 07, 2009
How to enable touchpad on Toshiba Satellite L850?
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Oct 27, 2012 | Toshiba Satellite L850-BT2N22 Customizable...
Toshiba Satellite L675d-s7040 touchpad scroll not working
The problem is the sensor pad, cracked ribbon wire, or the ribbon cable is not properly attached to the plug on the motherboard.
Apr 11, 2012 | Toshiba Satellite L675D-S7040...
My touch pad scroll function is not working on my Toshiba satellite M300 laptop
To use scroll function, you have to install the touchpad drivers, which are available from Toshiba Official Support. Click Here to download the required touchpad drivers. Select 'Touchpad' from Category and install Synaptics or Alps Drivers (Depending upon the type of touchpad you have on your system).
Hope it helps! Good Luck!
CreativeTECH
May 25, 2011 | Computers & Internet
I want to turn off the scrolling function on the touchpad. The pad is too small for this function and it gets in the way of trying to move the mouse around
To disable the scroll function go to mouse properties;click device settings;click settings;expand overview;and you will see the scroll option, that's where you can disable it.
Hope this works.
Mar 17, 2011 | Toshiba Satellite L635-S3040 Notebook PC
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
How do I stop the Toshiba Satellite A200 touchpad locking?
When using FN button, Hold button down then press Function button you want then release FN button.
Feb 01, 2009 | Toshiba Satellite A100-S8111TD Notebook
Touchpad
Go to the Toshiba website and download updated Vista drivers for your touchpad, and you should be fine.
Dec 28, 2008 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite Pro P300 Notebook Logo
2,169 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
