Question about Honeywell HS-300 16'' Stand (Pedestal) Fan
Fan stopped working
I bought a fan and it worked fine for about 3 months, then I moved it to another room, and it no longer works at all. nothing will make it turn on. I have contacted honeywell 2 times, with no response, and the phone number doesn't work for me, as I work the entire time it is open. is there anything i can do to try to troubleshoot the problem? I am by no means an expert, but I do dabble in electronics, e.g. I know how to use a multimeter. If anyone could help I would be very appreciative
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, moving the fan from one room to another should not cause it to cease operating. A couple of ideas you may want to consider/try:
  • with the multimeter set to X1, check the resistance of the 2 prongs of the AC plug;
  • selecting each of the speed other than OFF should show a reading;
  • if there is a reading on any speed selection and yet the fan will not turn, with the fan unplug, turn the blades manually. it should rotate freely/easily. If not, then possible dirt accumulation on the bearings or a stuck up;
  • if there is a reading, the blades turn easily and selecting any speed, the motor only hums but not turn, then the start up capacitor is faulty;
  • if no reading at all, then the unit has to be opened up to expose the rear of the switch and the wirings inside;
  • check for the continuity of the AC cord from the plug to where it enters the body of the fan;
  • if everything checks out, then suspect the motor. To check motor, there would normally be 6 wires from the coils; 2 for the starter capacitor, 1 for the common and three for the different speeds. Check their continuity.
Good luck and thank you for using FixYa.
Posted on Feb 14, 2009
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
I bought a pump for my fountain 4 months ago, it stopped working
This sounds like you should check your suction pipeing again and with fish be sure to get a screen for it. Then also check the impeller on the pump to be sure nothing inside it. You will need to open the pump to do this. If it has been working their is probally nothing wrong with the pump itself.
Dec 14, 2009 | Aqua Garden
My blower only works on setting 123 + air con not that cold
You have a resistor array assembly going out. What you described is typical of the first resistor going out and over loading the second, which goes out and overloads the third. Replace the HVAC resistor array. Don't buy a used one. Spend the extra money on the new OEM dealer item. Good luck to you.
Apr 20, 2009 | 2000 Jeep Cherokee
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Ceiling fan/light quit working with remote
Fan does not respond to remote, checked and replaced batteries in remote. No response, and unfortunately it is now well out o warranty but have the same fan in another room purchased same year 2003 which is moving along fine. Cannot find instruction book for either one. Please help. Thanks
Dec 11, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Honeywell HS-300 16'' Stand (Pedestal) Fan Logo
329 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
