Question about i-mate JASJAR Smartphone
I have a i-mate jasjar and Iam tring to use a tom tom gps sd card
My jasjar will not let me lode the tom tom gps sd card I have from a old unit that broke on me. It was a tom tom go 510 navagator. Is their anyway I can install this sd card or will copyright stop this and if so is their anyway around this
    President:
  • 2,976 Answers
It is a totally different kind of product. It's like trying to view documents on an sd card through your camera. You'll have to clear the card and reload it with information from the manufacturers website.
Posted on Feb 14, 2009
My tom tom one when i swith on the screen shows the sd card being removed from tom tom with a red cross across sd card.the sd card is in side .i can not past this screen or use gps how do i fix thanks
It is likely that the SD card (data) is corrupted. I'm assuming that it had previously worked properly.
Have you tried running a (fix) disk utility against your (internal disk or SD card) storage for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 24, 2013 | Tomtom One XL GPS Receiver
Update download for tom tom xxl 540s is too big for unit, lost all maps
Theres good news for you, you can get a SD card for your tomtom, and all you have to do is to install or download your maps on the SD card then fix it into your tomtom and you will be able to view your maps from there. For the lost maps, connect your tomtom to your computer, be sure to have your drivers software, then you select your tomtom form your computer, then you install all lost maps back on it by restoring all old maps. But for large downloads, download all new maps on a SD card. That should do the job.
Hope this information came in handy.
Dec 21, 2010 | Tomtom XXL 540S GPS Receiver
A while ago I put a larger sd card in to my unit,as i wanted to install the complete maps of the U.S.A, i PUT A uLTRA 2 GIG CARD IN, IT WORKED FINE, PUT MY GPS AWAY FOR A FEW MONTHS, YESTERDAy i put the...
Most likely you got a hot copy of the maps and it worked fine for a few minutes in the new unit. Check the course of the map because they know if they are purchased new or are being copied. Not saying you did anything wrong just saying the SD card can only be used for one unit. Contact the company and they will set you straight.
Apr 30, 2010 | Tomtom GO GPS Receiver
My tom tom one has been trying to find a gps signal all day. It is asking am i i na building? it whas worked perfectly up to when i booted up this am!
Have you tried a hard reset? if not switch off the unit remove the sd card and stick i pin/clip into the small hole by the sd card slot for 15 seconds, then replace the sd card and power up.
Feb 12, 2010 | Tomtom ONE GPS Receiver
Tom Tom XL Connected TT to laptop and selected scan and fix etc but dowload interupted and now says I dont have access to Map united Kingdom and republic of Ireland
I think maybe it needs to be reset mate, but take the sd card out before you reset it, press and hold the reset button for about 15 seconds and then turn it back on and then load the sd card and the maps should reload
Jan 02, 2010 | Tomtom ONE GPS Receiver
I have owned my Tom Tom One for a year now, and when I turned it on today all I have are different colored vertical columns. These columns take up about 50% of the screen and the remainde of the screen is...
try resetting the unit, make sure it is off, then remove the sd card, get a pin or clip and put it in the reset hole at the bottom of unit press and hold for 15 seconds, then restart the unit and replace the sd card, i hope this works for you mate.
Dec 30, 2009 | Tomtom ONE GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Memory card
Replace the SD Card.
Unfortunately not all card makes are compatible. ie: Tesco own brand being one
Good and reliable make is KINGSTON
Put your dodgy card into a pc card ready, copy and paste the data onto the new card.
If that doesn't work then I would say you have a tempromental card reader in your SatNav and need a replacement.
Let me know how you get on.
Mar 31, 2009 | Tomtom GO 510 Car GPS Receiver
Unblocking an I-Mate
Hi, the iMate JasJar is also known as the HTC Universal. Instructions on how to remove the sim lock can be found at
http://wiki.xda-developers.com/index.php?pagename=Uni_Simlock_by_Buzz_and_team
Dec 03, 2007 | i-mate JASJAR Smartphone
i-mate JASJAR Smartphone Logo
60 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
