Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Adjusting the blue convergence on tv
I purchased kit to fix tv .It is almost there but I cannot adjust the blue convergence up and down or right or left. The red worked fine. Which chip controls the blue.
  • Edward
    Edward May 11, 2010
    I beleive the blue is controlled by IC 7405 but as Crikett pointed out you may need to do more investigations.
    President:
  • Philips Master
  • 1,779 Answers
1st. Go back over your soldering and make sure you didn't break a trace and joints are solid.
2nd. Make sure you installed the correct value resistors in there places.
3rd. I believe the blue crt is on your right, follow the convergence leads down to the board to the 4pin plug. Go from pin 1 of the plug to pin 11 on each of the IC's ( 1at a time ) with an ohm meter, when you see 0 or just about 0 that will be the blue IC, I have the PTV 915 manual that i'm using. I suspect you will find a mistake along the way. Take your time and double check everything again and let me know. Good Luck!
Posted on Feb 14, 2009
Adjusthow do I adjust the convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jul 03, 2010 | Televison & Video
Conversion, colors overlapping purchased in 2006 no issues other than 3D look
  • Screen looks 3D
Mar 12, 2010 | RCA R56WH76 Projection Television
I have a problem with my convergence. I cannot get the cannons to adjust with the remote. I have red shadowing around the picture and the adjustment for convergence around the outside of ghe screen wont...
  • Screen looks 3D
Jan 17, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Cant adjust the blue its all over screen its a hitachi 65s500
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 02, 2009 | Hitachi 65S500 65" HDTV-Ready Rear...
I have a blue wave on my screen
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Blue line
  • Screen looks 3D
Jan 28, 2009 | Hitachi 43F300 43" Rear Projection...
Apex GB43HD10 Convergence
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Tv has a the blue tint that won't line up.
the problem is with the convergence, 1 or more chips could be faulty. replacement is the oly option if faulty stk-xxx-xxx
Dec 26, 2008 | Philips Magnavox 51MP392H Rear Projection...
ALOT OF BLUE ON THE SCREEN!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 20, 2008 | Philips 60PP9200D Television
Hitachi 50" 50GX30B PJTV
Solution:
Screen looks 3D
Screen is bowed in but stationary.
They have put together a kit for the Hitachi TV sets.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
