Question about Dell E173FP 17" LCD Monitor
E172fpb monitor that turns on, but then goes dim
The no connection system test comes on then it keeps on moving around the monitor, but it is so dim that it looks like it is off.
  • 1 more comment
  • mjones843 Feb 14, 2009
    I tried that. but doesn't seem to go into the menu. When if first turns on, it is bright, but then goes dim. You have to really look at it to see that it is still moving around the screen.
  • Buddy Mcsparrin May 11, 2010
    Hello, Your backlight inverter inside the monitor is out. If you are comfortable soldering you can repair it yourself. We have a step by step repair guide on our web site at: www.ccl-la.com/LCDrepair5.htm I hope this helps, If so please rate my solution. Buddy Corporate Computer
  • Rigby810 May 11, 2010
    see if you can navigate through the on screen menu to turn up the contrast or brightness. does that work?
  • 555 Answers
Your display have an inverter driver broken, So the back light can't turn on. Here is a website that shows this issue:
http://josepino.com/?howto-repair-dell
Posted on Sep 04, 2009
I have a Dell E172FPb flat screen monitor. The
There are two possibilities, one is bad caps in the power supply, number two is shorted out transistors (P/N c5706/5707) in the inverter circuits. Please open it up and report back what you see so we can guide you further, see example fo failed monitors due to bad caps, lamps, etc: http://s807.photobucket.com/home/budm/allalbums
Jan 30, 2010 | Computers & Internet
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My Dell E172FPb flickers & has straight, thin
#1 Connect monitor to another system, make sure the issue is the Monitor, not the video card.
#2 Try a different VGA or DVI cable
If the issue is isolated to the monitor, it is cheaper to replace it than to repair it (Refurb 17" LCDs are $69 on Dell's Outlet
Jul 02, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
E172FPb Flat Panel Color Monitor black screen problem
Buddy
Corporate Computer
Mar 15, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E172FPb screen blinking
If you've tested turning the monitor on without the VGA cable and it's still blinking I'd say there's a problem with one of the capacitors on the power supply card on your screen, when you're able to check it would you mind telling me the brand / reference of it ?
Nov 04, 2008 | Dell E173FP 17" LCD Monitor
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
Tried to fix dell e172fpb
is the transistor the exact match?? checkif it is overheating??
let me know..
Nov 25, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
688 people viewed this question
Alun Cox
