Question about LG WM-2277HW Front Load Washer
I have an LG front loader, model WD1018C. machines completes the wash cycle, then comes up with error: OE and stops.
    Sergeant:
  • 326 Answers
That OE is really DE (drain error). Open the access door at the lower left on the front of the washer. Drain remaining water using the small hose. (at least if it is not plugged) Unscrew and remove the large knob. Clean out filter. If filter was clean, you may need a new pump motor, or something may have made it past the filter and is jamming the pump impeller. You can remove the pump without taking the front off the machine.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Feb 14, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On most LG models of washing machine, error code "OE" indicates blockage in the impeller/pump area. This then calls initially for a visual inspection and cleaning debris out. Cleaning is relatively easy but a bit messy. It would require access to the bottom parts either through the kick panel or the rear panel. Other than the above mentioned drain parts, you might as well considering checking/cleaning the drain valve, sump/bowl, filter and drain hose (kinks). Should cleaning be not corrective, then you would need a DVM/VOM to check for the presence/absence of supply voltage to the pump motor.
Good luck and thank you for using FixYa.
  • 10,515 Answers
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
BUT!!
My LG1372 FHB has the same fault and it isn't blocked - am looking at the pump next!!
- checked the hoses (drain hose) and the pump filter but it didn't cure the problem.
So i turned the damned thing upside down and stripped the pump out of it - sure enough there was a piece of cotton cord wrapped around the impellor - remove it and everything is OK!
More explanation :)
Memory serves me correct, the 0E code is a blocked pump which is consistent with what you are saying. I have included a link from Stokes Aus.com that will give you the exploded view and parts list of this model. Just go down the list to yours. The pump is located at the front so you should be able to remove the bottom front cover to access it. The little access panel might give you access as well. I can't remember. I don't work on any off shore machines any more so my memory is thin. Hope this helps
http://www.stokes-aus.com.au/StokesAP/info_sheets_LG_Washing_Machine.asp
Thanks.
    President:
  • 1,902 Answers
"OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check wiring harness
· Check water inlet valve
· Check pressure sensor switch
· Check circuit board
  • Jeremy Reddick
    Jeremy Reddick Feb 14, 2009
    All located behind the front panel
  • Jeremy Reddick
    Once you found the bad part go to www.repairclinic.com
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Sep 03, 2010 | LG WM0642H Front Load
My lg 7KG 1405F model in does not complete the washing cycle stops at rising (oe) is the code
OE is drain error, which means that the machine has detected that the water level is not lowering quickly enough...Probable cause is a blocked pump filter...Check via small door at floor level..Unscrew pump cover and clear filter....Remember that all water will drain from this point, so drain machine first...Leaning the machine back can help...Good luck....Nomess
May 20, 2010 | LG WM-1480FHD Front Load Washer
I have an lg front loader washing machine...it keeps stopping mid cycle and gives a troubleshoot code of oe...i cant find my owners manual and the lg site is awful....can you help me?
OE is drain error..Most likely problem is partially blocked pump filter...This is accessed via the small door at floor level...Unscrew the pump cover and clear the filter..Any water in the machine will flow from the pump cover...Empty the machine first...Leaning it back can help....Good luck....Nomess
May 14, 2010 | Washing Machines
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
Westinghouse Front Loader LF708C
You will find that the pressure sensor sampling tube is blocked with soap deposits. Needs to be cleaned out for the sensor to work properly.
Jul 18, 2008 | LG WM-2277HW Front Load Washer
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
57 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
