Question about Apex Digital AT2708S 27" TV
Turning on and off on it's own
The tv keeps turning on and off. It will play for a few minutes then shut off. stay off for a few minutes then turn back on. Also the volume doesn't work now It stopped working the same time the tv did.
  • 129 Answers
Theres a possibility that the tac switches of your unit got stucked thats why your units function is intermittent. Try to have your buttons removed and have your units circuitry be resoldered.
chris
Posted on Feb 14, 2009
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
MY ILIVE SOUND BAR KEEPS TURNING OFF WHEN WATCHING TV
I'm having the same problem. I don't think it has anything to do with the Sleep settings, you can play with them all day & the only benefit you may get is forcing it to stay on for 90 min or whatever instead of 15.
(I've tried setting to 00, obviously the first thing that comes to mind is that it's a Sleep Setting issue, but I seriously doubt this. You can't even set the Sleep Setting to 15min anyway)
Instead, I'm pretty sure that the problem exists in the sound bar not recognizing that there is an active signal & is shutting off due to what it sees as inactivity (timing out after use). I've come to this conclusion due to multiple complaints of the same problem.
Some people are reporting that it's not happening when they watch movies, others have tested & said the radio stays on as long as you like, a couple people have posted that theirs works fine & only shuts off when they turn off about 15 minutes after they shut off the audio source, which leads me to think that this is what is going on, the system thinks the audio source (TV, Bluray, etc) is off & no sound is coming through. It must have a funny way of detecting it...
I will try a few tests & if anything works I will pay the results. One person claimed there's stayed on after turning their TV all the way up... I could try this but will have to turn TV speakers off (currently I am running both TV speakers & sound bar). Anyway, I'll keep digging, must be some way to get this to work, I hope...
Jan 20, 2013 | iLive ITP582B Soundbar iPhone Dock
My TV won't stay on until it's warm?
have your unit power supply check, maybe some cold solder or leaky capacitor is the culprit.
Aug 01, 2009 | Philips 42PFP5332D 42 in. Plasma...
The tv keeps shutting off just after minutes of turning it on. We can wait about 5-10 min before turning it on again but then it only stays on for a few minutes.
This sounds like a heat related problem, which could be a faulty chip or a cold (bad) solder joint on one of the PCBs (printed circuit boards). Due to the lethal voltages present inside a CRT type television, it is strongly advised to have this repaired by a qualified technician. however, if you or someone you know is technically inclined, you can try to fix this yourself. Cold solder joints can often be spotted by visible cracks in the solder joints. a through inspection of all the boards could easily identify the problem which can be resolved with a quick tap with a soldering iron and perhaps a little extra solder added to the joint. if that yields nothing, another method is heat/cold stressing the boards while the TV is running. With the TV on, spray small areas of the PCBs with cold spray (or a can of compressed air duster turned upside down) until the tv shuts off. then heat the last sprayed part with a hot air gun (or a hair dryer) until you can get the problem to repeat regularly. inspect the area causing the problem and you will probably find the culprit.
May 26, 2009 | RCA TruFlat 27F520T 27" TV
TV shuts off on it's own. Turns on fine, stays on for a few minutes, then something clicks inside, and it shuts off, and can't be turned on with remote. I then spend the next 5-10 min turning it back on...
This is because of a power supply unit going out inside and there is not much you can do accept for have it repaired or think about new at this point also with the new digital tv standars comming out you are going to need a box for this if you doing OTA anyways so at this point if you are not inclided to haing it repaired have it recycled.
May 14, 2009 | Televison & Video
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Tv shuts off
This shutting on and off~On Durabrand TV`S. If your Tv Turns Off after about 1-11/2 minutes after turning it on then you need to replace your batteries in your remote control with BRAND NEW BATTERIES or it will keep doing it. It is a real pain in the behind especially if you dont have brand new batteries handy!
Dec 06, 2007 | Durabrand DWT1905 TV
RCA RT2250 consistant shutting off in Satalite mode.
Mine will always just turn off every minute or so after a hard shut down(ex: power outtage). I have to turn it back on and then hold the set button for a few seconds, then it stays on, until i turn it off manually, since the remote won't turn it off.
May 15, 2007 | RCA RT2250 System
Apex Digital AT2708S 27" TV Logo
281 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
