Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Cant Get sound from CD Player when Connected to Phonic Live Mixer
I have the right cable...
i am plugging it into the right spot... i can barely hear it, when i turn the volume all the way up.
i know its not right...
what do i do?
  • 55 Answers
Posted on Feb 21, 2009
Hey . just wondering how do i connect my phonic max 2500 amp to my Numark M6 USB mixer. then i will be connecting my laptop up to the mixer..
The M6 has balanced XLR outputs on the back, which can be connected directly to the XLR inputs on the back of the Phonic Max 2500. You just need two XLR cables.
Feb 20, 2013 | Numark M6usb M6 Usb Four Channel Table Top...
How to connect it ?
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Jun 19, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" may try reducing your input gain on each channel of your well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
When i plug in my mp3 into the phonic system it doesnt play certain notes of songs and there is no bass
It sounds like the cables you are using, or the way you have it wired into the system are not correct. If you are using the stereo channels on the mixer, then the system also needs to be wired in stereo to the proper amp and speakers. Otherwise you hear the left or right side of the stereo mix, and not all of the music correctly.
Another problem may be the kind of cables you are using to wire the MP3 player to the mixer with. If you are using a 1/8" adapter to the MP3 player, make sure it is a STEREO 1/8" adapter, and that both left and right channels are plugged into the mixer, preferably on the first two inputs to test and see that both channels are indeed coming through. Then you may move them to a stereo channel. Again, make sure that the system is wire in stereo in order to hear both sides, Good Luck
Mar 23, 2011 | Phonic Am240d Compact Audio Mixer W/...
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
CDJ 1000Mk1... No sound coming out the right output? Can anyone point me in the right direction please?
Hi, Have you replaced your cable for that cdj, check your mixer aswell. if you havent got your player repaired and you live in the uk then you can try this site.
Hope this has helped you.
Feb 02, 2011 | Pioneer CDJ-1000 CD Player
Phantom power will not wor on my phonic 620 cd jacks will work but when i plug in a mic it will not work help
I assume you are using CONDENSER microphones, as these are really the only ones that can use Phantom power. Also do NOT use any MONAURAL connections to MIC jacks while using Phantom power.
Dec 12, 2010 | Phonic NEW PHONIC SONIC STATION 22 MIXER...
No sound
Your power amp should be connected to MAIN OUT left and right. NOT the MAIN "in".
The CD is connected correctely as you described. Make sure the CD has a line level output to match the input expected by the mixer.
Note:Walkman style CD players require a special cable to go between 1/8 inch stereo to dual RCA plugs.
You have to advance the MAIN fader.
You should be using TRS interconnect cables from the mixer to your amps OR using XLR cables.
Jul 24, 2010 | Mackie 1202vlz3 12 Channel Mixer
Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
Aug 29, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Car Audio & Video Logo
46 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
