Question about DeLonghi DE400 Dehumidifier
My dehumidier keeps beeping
My dehumidifier keeps beeping
    President:
  • 1,902 Answers
Check the filter and make sure that the water level is correct. If all is correct then replace the water level sensor
Posted on Feb 14, 2009
I have a danby dehumidifier...when I turn it on the fan goes on, but the actual dehumidier does not...the light about the first button does not light up. What Can i do?
It's probably in the wrong mode. This could be from a number of causes including you have not emptied the water chamber.
Aug 13, 2014 | Danby Dehumidifiers
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
MY FEDDER DEHUMIDIER RUNS ALL THE TIME AND CLLECT VERY LITTLE WATER AND THE AIR FILTER IS CLEAN.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 18, 2011 | Fedders A7DH45B2A Dehumidifier
Ice and condensation on top surface of LG dehumidier
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Aug 12, 2011 | LG Dehumidifiers
My dehumidier is not pulling any water into the bucket. Runs fine. About 1 year old.
If the unit is not pulling water into the bucket its probably not that humid in that area anymore. If it aint broke dont fix it.
Jun 27, 2011 | Dehumidifiers
My Goldstar Dehumidier quit working... there is no collection of water off of the coils making it useless. What can I do?
Have you checked to see if the collection basin is full. If so empty it and it should start.
May 02, 2011 | Goldstar DH304 Dehumidifier
My Maytag 45 pint model M7DH45B2A dehumidier stops working before the bucket is full. The bucket is around 20-30% full, the dehumifier will stop as if the bucket if full. I empty the bucket and reseat...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 25, 2010 | Maytag M7DH45B2A Dehumidifier
Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Apr 21, 2008 | Kenmore 54501 Dehumidifier
Dehumidier Delonghi DH400P not removing any water from the air
Only thing I can tell you to do is to make sure that the evaporator in the back is ice and cold. If the evaporator is not cold the unit will never remove moisture from the air. And if that is the case you have a sealed system problem. The unit may have a leak so there is no gas in it. The compressor may not be working or the humidstat my not be working properly. So check those thigs out or if its under warrenty call for service.
Jul 11, 2007 | DeLonghi DE400P Dehumidifier
DeLonghi DE400 Dehumidifier Logo
766 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
