Question about Toshiba 50HX70 50" Rear Projection Television
50HX70 picture The picture on my 50HX70 looks like it went 3d on me. I see posting about the convergence board. Is this costly to repair or shall I replace the whole TV? Thanks.
    Genius:
  • 1,139 Answers
Hello jcside,
its not a costly repair the parts cost about $13.99 each (Convergence Amplifier ICs) Just remember you will need to change both of them. Also you will spend about $10 - $15 on the bias resistors.
Here is some advice I posted sometime ago, it applies in your case:
This denotes a convergence problem as you surmised. Believe it or not it would be cheaper for you to replace the two convergence amplifiers and the biasing resistors. You would not actually be replacing the convergence board since these devices are usually located on the deflection board in most cases. However in answer to your question, the boards are easily removed, depending on your level of patience (lots of cables to move around), I would also advise you to either mark down all of the connection you will remove, or take pictures of the board and its connectors. If you choose to just replace the Amplifiers and the biasing resistors there is a lot of information on this site on how to do so: This will get you started:
1) Unplug the TV and then get a schematic of the TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK392-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK392s are 110, 120 or 150.
4) if the STK392-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5)Now to replace the STKs: remove the module from the TV and unsolder theold STKs along with the bias resistors, and replace them with the newones (be sure to apply heat sink paste to the STKs when attaching themto the heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do manual adjustment and the auto-convergence test and then things should be back to normal.
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.com
Now if you think you can do this have at it, if not I would suggest that you have it done by a qualified TV technician.
Posted on Feb 14, 2009
I am getting a blurry picture that kinda makes it look like a 3d movie without the glasses on with alot of blue
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is the causes and already dead to have many of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures many problems.The tvs shops will cost u like $300-$350 for parts and labors.
Sep 07, 2011 | Panasonic Televison & Video
Has a 3d affect
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any kind colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes all of these problems.The tv convegence board have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 31, 2011 | RCA P52940 52" Rear Projection Television
Double lines
Tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to caused these problems.The tv convegence board must have be repair like repalacing parts like 2 STK convergence ICS and some or all of it resistors too.To repair the tv convergence board to solved tv convegence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | Sony KP-51WS510 51" Rear Projection...
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
Picture looks 3d colors not lining up
The tv have a problems known as a convergence picture problems.That why ur tv colors lines R,G,B are mis alignments,have colors shadow pictures or have 3D pictures look alike?The tv convergence board it is dead.Tv Convergence board must have it parts like 2 STK convergence ICS and some or all of resistors to be replace too.To fixed the tv convergence board to solved tv picture convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 09, 2011 | Panasonic PT-53WX54 53" Rear Projection...
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
The red coler has started to curve about a third of the way down the screen. everything on the the screen is distorted and doubled in red
if your picture looks 3d it is convergence problem.
This is a do it yourself repair if you have some skill.
I will tell you what you need and have start to finish, step by step instructions for this repair along with photos, and source for parts needed(parts cost will be under 30 dollars).
reply here if I can help.
SD TECH
Oct 24, 2010 | Mitsubishi WS-55807 TV
MY TV WENT BLURRY AND DOUBLE..WHAT SHOULD I DO?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows pictures or look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require replacing,to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 21, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model# 53UDX10B bought in 2002. The green color has went off. Its a red tint picture now. Whats the repair and the approximate cost.
The tv have a problems known as a convergence problems,it dead.The tv have colors R,G,B lines mis alignment,have colors shadows or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 11, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 50HX70 50" Rear Projection Television Logo
190 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
