Question about Sony KDF42E2000 42" HDTV
Tv plays for a few minutes then shuts down. the red light blinks.
I just replaced the dlp bulb in my SONY KDF42E2000 when I turn it on
the screen says the the bulb is nearing the end of it's life and should be replaced soon. plays for a little while and then shuts down. when I first
inserted the the new bulb it wouldn't come on. I tapped it on the back side and the bulb lighted up for the first time. As I attempted to move the tv into place(pushing the stand into viewing position) it went out. the way it stands now. when it is turned on it plays for a few minutes and then shuts down. the red light continues to blink until you push the power button. once to green then to turn it off. This tv is a little more than a year old!
  • maybintm Feb 18, 2009
    Thanks for the advice. after removing the bulb holder. i did an adjustment to the two side metal hooks that locks the bulb holder in place. i also checked for any physical obstructions. then replaced the lamp door, making sure the open close handle moved all the way.
    plugged it in and turned it on . today is the second and it's still
    playing. at the top of the screen is a pinkish translucent line about an inch wide. it's that bad but needs to be resolved any idea?
    President:
  • 196 Answers
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Posted on Apr 20, 2010
    Problem Solver:
I replaced the lamp now the screen lites up then pops up lines shut off red blinking this happens in amatter of seconds
Posted on Aug 25, 2011
    Novelist:
  • 184 Answers
The problem may be the lamp door is not aligned properly. Also, the display message that the lamp is near the end of its life will continue to come up until the lamp hours parameter in the servicer menu is reset. Accessing the service menu requires a code from the remote. I do not recommend that you attempt to do this yourself because you can easily cause irrepairable changes to the TVs operation if you hit the wrong button on the remote.
michtech
Posted on Feb 14, 2009
  • Billy Bauer Feb 18, 2009
    You should look at a few of my responses regarding optical block(light engine) problems that Sony has been having with thses TVs. If the pinkish area grows, its likely that the light engine is bad.
    michtech
Tv will power on not picture
I would have the power supply checked for the screen and then have the power button checked it may be faulty.
Sep 20, 2017 | Panasonic WD65638 Mitsubishi WD65638 65""...
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Problems with the power on a sony hdtv KDF42E2000
Maybe the probles is with the ballast. the ballast # is A-1247-118-A, no longer available, the replace ballast # is A-1247-19A, is the same.
May 19, 2009 | Sony KDF42E2000 42" HDTV
Picture cycles off and on
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
,,,,Pat
Nov 21, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KDF42E2000 42" HDTV Logo
627 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
