Question about Behringer EUROPOWER EP2500 Amplifier
No output on CH 1
+15vdc supply is missing.-15vdc is ok.zener diode(D12)checks ok.
ANY SUGGESTIONS?.
  • 1 more comment
  • patseunath Feb 17, 2009
    no LMs or 7815s.
    there are two /12watt zener diodes for regulation.
    also some one asked about 8.4k "droppers",these are the "droppers"(load resistors) for the zeners so they will get pretty hot.
    they are supplied from the +-110vdc.
    +-95vdc are across them so they WILL GET HOT.
  • Scott Frye
    Scott Frye May 11, 2010
    Behringer used a resistor and zener off 110 DC for 15 volts?!?!?!?!
    Yikes!!!
    I have the schematic.
    Email me at painintheamp@yahoo.com
  • Scott Frye
    I would think that they use an LM-series or 7815 series reg for the + 15. Can you find either inside?
Sony TV has a power supply problem both ics irf1b7n50a in the power supply section are all shorting which number could I use as an equivalent. is there a way I could use a power modular with two power id's
Hi Saidi
Have you checked all the other components used in the main power supply regulator section circuit, before replacing a new STR? You should do it. There should be a reason for the failure to STR. You should find it, and rectify it, before replacing an other STR. Check all the small components, resistors, zener diodes, small value ceramic capacitors etc: Make sure all of it are OK. Especially give a keen attention to zener diodes used; if any. It will be best to replace these diodes, even if you do not find any fault with it with multimeter test.For more information go to http://electronicshelponline.blogspot.com/
Power supply schematics to some popular brand TVs are given. Pull up older posts. Good Luck.
Nov 26, 2013 | Televison & Video
What is the zener volt
I'm not sure what your question is. A zener diode is a voltage regulator of sorts. The zener voltage is the avalanche voltage...the voltage that the zener diode will maintain when it's connected in series with an impedance, usually a resistor, IF the voltage across the zener diode and the impedance, in series, is greater than the avalanche voltage (zener voltage), and the polarity of the voltage across the zener diode is thus: positive cathode, negative anode (i.e., reverse bias). The excess voltage (the margin) appears across the impedance. Zeners are often used as voltage reference diodes in regulated power supplies. Does this answer your question?
Apr 16, 2013 | Computers & Internet
My hitachi 29in ctv power supply 110vac had a problem on zener diode will blown if we switch on the tv. what spare parts to change so that the power supply zener diode will not blown again and the supply...
The secondary output voltage comes out from is more than it should be there. That is why, the protection zener diode blows off, as soon as you switch ON the set. First find and repair the power supply regulator, for correct output voltage. Refer its repair book for details. After repair include the zener diode in place. OK.
May 08, 2012 | Hitachi Televison & Video
Emerson mod. ewc 1301 keep blowing fuse
Hello
There must be a direct short in its power regulator section. Normally a shorted switching output transistor at power regulator section will cause this fault. You have to check all the components in the power supply switching retulator section, including rectifier diodes, zener diodes, electrolytic capacitors, small signal switching transistors etc. In fact, you have to check the components in the entire power regulator system. Never put any more fuse into it as an experiment; this will make more components to get damaged. Check the sets' circuit well. OK.
Jul 27, 2011 | Emerson EWC1901 Combo
Rebuilding plasma moduel # 6871QYH053B, three diodes missing!!! need markings on D1 D7 & D12 , Thanks rioconcho
I’m not seeing a direct break down of that 42” Y-Sustain board to see the D1, D7, and D12.\
Look below for the complete diode parts locations, part numbers, and ratings for the 42PC3d-UE.AUSLLJR. That TV has the 6871QYH053B board you asked about.
I hope my information has helped you.
Good Luck.
May 24, 2010 | Televison & Video
Tv keeps going off
check the ac output socket if its working, power supply is not working
check the following
switch contacts fuse, semi conductors transistors,diodes, zener diodes, fuse resistors,
this will make your tv to oscillate
Apr 11, 2009 | Philips Magnavox 42MF521D/37 Television
Tv shut down
Good day.
Have you cheched on your vertical IC? The zener diode along B+ and try to check zener diodes along the secondary supply form your flyback.
chris
Feb 26, 2008 | Sharp 19L-M100 TV
Tv does not power up
I have seen the schematic, d982 is a 13v 1/2w zener
-GR
Jun 28, 2006 | Mitsubishi CS-35503 TV
Behringer EUROPOWER EP2500 Amplifier Logo
119 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
