Question about Singer 8280 Mechanical Sewing Machine
Breaks needle Hi-my wife has a singer prelude model 8280. She was sewing one day and the needle broke. She checked the bobbin etc-replaced the needle and it broke again. I looked at the machine-the bobbin holder seems to be in correct, but the needle comes down and hits the bobbin carrier.Can these machines suddenly get out of time (i'm a mechanic unfamiliar with sewing machines) If it is out of time does anyone know the timing procedure and what would cause it to go out of time. I removed the cover and inspected the gearing-it seems fine-thanks for your input
    Sergeant:
    Champion:
  • 240 Answers
Yes they can indeed go out of time and breaking needles is the most likely cause. To solve timing problems you will need a sewing machine engineer though. The part which needs adjusting would be the area above the needle-the needlebar but it is a fiddly affair only to be attembed by someone who can repair sewing machines. It is also a fairly expensive repair as it is very time consuming. However-don't assume it is that. Firstly make sure the new needle is in correctly-the most common cause of problems is needles in wrong direction! If bobbin opens at front then the flat part of the needle faces the back. If bobbin area opens at side then the flat side of needle faces the body of the machine to the right. Check needleplate for damage so that new needle does not catch. File it smooth if you need to! Check you are using a good quality thread as cheap thread causes no end of problems. Guuterman is the best I found.
Posted on Jun 11, 2009
Frequent thread breaking
Hai, Please check the thread tension and change the new thread and new needle. Otherwise put the some drops oil in the top and bobbin thread. Or go to mechanic shop.
Apr 16, 2014 | Singer 8280 Mechanical Sewing Machine
Singer Prelude 8280 Sewing Machine stuck
Is the knob on the side, where you loosen the needle to rewind the bobbin, tightened? Also, there may be some threads in the bobbin case messing things up. Unplug the machine if you are checking the bobbin case.
Apr 18, 2013 | Singer 8280 Mechanical Sewing Machine
Why is my singer SEWING MACHINE prelude HAND WHEEL RESISTING
Make sure the bobbin winder is in the position away from the bobbin stopper. When you fill a bobbin, you have to push the "spindle" towards the handwheel. If you do not push the "spindle" back into position (away from the handwheel), the wheel will remain locked.
Jul 18, 2012 | Singer 8280 Mechanical Sewing Machine
I have had a singer prelude 8280 for a year now with no problems. now all the sudden the thread is catching in the bobbin casing. The thread on top looks normal, but when you turn over the fabric...
It is in your top threading, try this test, rethread, now with the presser foot up, pull the top thread, it should feed smoothly, now lower the presser foot, it should barely move. Sometimes this seats the thread in the tension discs. Also, make sure that your needle is fresh.
Nov 20, 2010 | Singer 8280 Mechanical Sewing Machine
change the needle
clean under the needle plate where the feed dogs are for lint
make sure the thread has not come off the thread take up lever
rethread the machine
Needle broke and i changed with the same number now it is not picking up the thread and does not stitch
you said the needle broke, did you check in the needle plate where the feed dogs are if there was any needle fragments
also check in the bobbin area for needle fragments, take the bobbin case & bobbin out & clean the area
Oct 21, 2010 | Singer 8280 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
315 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
