Question about ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard
HARD DISK IS NOT DETECTED
After computer on hard disk is not detect or hard disk file
Mother bord no power
Posted on Mar 28, 2009
  • ASUS Master
  • 2,382 Answers
Check the data cable and power cable connectors of the harddisk, otherwise the hard disk check on other computer.
Posted on Feb 14, 2009
My mother board on desktop is P5KPL-AM SE it is not detecting hard disk after installing windows on new hard disk it goes on repeatedly rebooting never shows windows if i tweek bios setup the windows...
check you bios setting
1st boot should be your hard disk if your hard disk model is not shown in the selection then select HDD-0 as your first boot this will solve your problem
this solution only works if your hard **** is detected during POST if not detected check the power connector and SATA or IDE cable of your Hard Disk
Sep 21, 2011 | ASUS P5KPL-AM SE Motherboard
Bootable device has not been dectected
When the PC cannot see a boot file/disk on either thehard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press anykey" First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk. If there was no disk in the floppy drive then it maybe a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case andre-seat the data cable on the hard drive and also where it connects to themotherboard disk controller.
If it still gives this error message and the BIOS does not detect this harddrive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to anUSB hard drive adapter and connect it to a working computer's USB port, if thiscomputer does not detect it as an external storage device then the hard driveis faulty.
To get the computer operating again, install a new hard drive in your computerand then install Windows on this hard drive plus the computer's devicedrivers and your programs.
Aug 24, 2011 | Intel D946GZIS Motherboard
Could not proceed to boot
To check your hard disk drive if its detected, turn on your computer and press DEL or F2 to enter BIOS setup. Then go to standard cmos setup and there should be the hard drive detected as Primary or Secondary IDE or SATA. If detected and not loading into windows that case your operating system is corrupted. However If your hard drive is not detected on your bios, turn off your computer and unplug and plug your hard disk drive then turn on your computer start pressing again DEL or F2 then check again your hard drive if it is detected.
If your hard disk drive and cd/dvd rom drive are the same cable you can switch the cable to check if the cable of the hard drive are ok. After you have checked and you found out that the two cables are ok that means you will have to format your computer. But you must backup all your data and files before doing so. Formatting your computer will erase or delete the entire space of the partition which you perform formatting.
Here is the video tutorial on how to format your computer using windows xp
Have a nice day.
Apr 05, 2011 | ASUS Computers & Internet
When my laptop boots up it says operating system not found
Not good. Check your bios for correct drive for boot up, but it sounds like yoru hard drive is not being read....
Oct 26, 2010 | Acer (ACERMOTHERBOARD)
P4pe x cannot detect hhd drive
If the BIOS cannot detect the hard drive then :-
1. The hard drive data cable or power connector may not be inserted properly.
2. The motherboard disk controller is faulty.
3 The hard disk is faulty.
To test the motherboard disk controller, connect another hard disk to the motherboard and go into the BIOS to see if it detects the hard drive.
If it detects the hard drive, then the other hard drive is faulty and need to be replaced.
Another way to test the "faulty" hard drive, connect the hard drive to an USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the folders and files the the hard disk is OK, and the fault is a faulty disk controller on the motherboard.
Jun 14, 2010 | ASUS P4PE-X Motherboard
Hardrive not detected
You may have a hardware fault.
Try re-seating the hard drive.
Then check the BIOS to see if the hard disk is detected.
If the hard disk is not detected then either the hard disk is faulty or the disk controller on the motherboard is faulty.
To further test the hard disk, remove the hard disk and connect it to an USB hard disk adapter and plug it into a working computer's USB port. If this computer cannot see it as an external hard drive nor can you open the various folders and files, then the hard drive is faulty.
Then you need to replace the faulty hard drive, install Windows on the new hard drive, together with the laptop's device drivers and your programs to get a working laptop again.
Feb 25, 2010 | Asrock 775i65G Motherboard
My computer worked properly. but at once my IDE devices started giving troubles. my 2 IDE devices are not detected at the start up.
The BIOS will have trouble detecting faulty IDE devices, eg the hard disk etc.
To check if the IDE devices are faulty, connect the hard disk to an USB hard disk adapter and plug it into a working computer's USB port, if the computer detects it as an external hard drive and you can open the folders and files then the hard drive is OK and the fault is the disk controller. If the hard disk is not detected then it is faulty and a new hard disk is needed, Windows installed on the new hard drive together with the device drivers and your programs to get an fully functioning computer again.
Sep 01, 2009 | Intel D865GBF Motherboard
Boot failure Asus P5Q-EM
Disk boot failure. Issue:Disk boot failure.
Cause: This issue could be caused by any of the below possibilities.
  1. Boot options are not set properly in CMOS
  2. Non bootable disc or USB in computer
  3. Remove added hardware /check connections
  4. Hard disk drive is bad
Solution:Boot options are not set properly in CMOS
Verify that the boot options within CMOS are set properly. Below is an example of how we recommend the boot options be set. Additional information about how to enter CMOS can be found on document CH00192.
  1. Floppy drive
  2. CD-ROM drive
  3. Hard Drive
  4. Other / Network
Non-bootable floppy diskette or disc or USB in computer
Verify that there is no floppy diskette or disc in the computer. If the boot options are set improperly the computer could be trying to boot from the disc drive instead of the hard drive.
In addition to verifying there is no disc in the computer make sure that no USB jump drive, external hard disk drive, or memory stick is inside any memory card reader.
If you're wanting to boot from a floppy diskette, CD, DVD, or USB drive and are getting this error message and have verified that your CMOS settings are in the proper order as explained in the above paragraph the diskette or disc you're using is either bad or does not have the proper files on it to make it bootable.
  • Additional information about how to make a boot disk can be found on our boot disk help page.
  • See document CH000669 for information about creating a bootable disc.
Remove added hardware / check connections
If you've recently installed any new hardware it's suggested that it be removed to verify it's not causing this issue. If after the device has been removed the computer works and it was another IDE / EIDE device ensure that the jumpers are properly set on the hard disk drive.
In addition to removing any new hardware it's also suggested if you've recently moved the computer or installed anything inside the computer that the connections for the drive be checked. Usually it's best to simply disconnect the cables from the back of the drive and reconnect them to make sure they're connected properly. While inside also disconnect and reconnect the cable connected to the motherboard as well. While inside your computer make sure you're aware of ESD.
Bad hard disk drive
If you have followed the above steps and you continue to experience the same issue, unfortunately it is likely that the hard disk drive is bad or the controller is bad.
If available, you may want to connect another known good hard disk drive to the computer to determine if it can be detected. If it is able to be detected then replace your hard disk drive. If it is not detected, unfortunately you will need to replace the motherboard or controller as it is bad.
If no additional hard disk drive is available it is recommended that the hard disk drive be replaced first or that the computer be serviced / repaired.
Jul 01, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
Hard disk not detected
hi im josh in cebu phils.may i help you? if it happens when the hard drive not detected and sometimes detected. your main problem is the IDE or the SATA cable.try to change it because it is faulty. and be sure to mount it properly when you change the new one. thats all good luck friend hope i helped you.
Feb 27, 2009 | Computers & Internet
Ibm hard disk not detected
do u want to install the hard disk or do u want to setup raid? getting the hard drive to be detected has nothing to do with setting up RAID.
Dec 24, 2007 | ASUS Intel 440BX Chipset CUBX-L...
ASUS Intel 845 Chipset P4B (P4B WOA) Motherboard Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
