Question about OKIFAX 5650 Plain Paper LED Fax
Toner sensor error 5650 oki
Turned on oki 5650 fax and machine displayed power failure report printing, then the alarm light came on and it displayed toner sensor error, check drum unit, paper started to feed from drawer and made it to the two black rollers that are side by side under the drum unit. This will happen every time the machine is turned on and off. The hopping roller was replaced a short time ago as well as the two gears with one way bearings associated with the hopping and resist rollers, also two other drum toner units were tried. Help?
SOURCE: Oki Fax 4580 problem
Does this happen when you perform a test print such as an activity report or config page? if it does you may have a transfer roller issue. The transfer roller is the long black spongy roller directly under the drum, the metal rod in the roller conducts a charge that interacts with the drum. If the roller is dirty (usually chocked up with toner) the necessary charge is diminished and the image will be lighter. You will have to remove the roller in order to clean it, (TURN THE POWER OFF) there is a bendable plastic tab at the right side end of the roller that will release the roller. I personally drench the roller with metho and then wrap a rag around it and squeeze the metho/toner out (dont do this with lexmark rollers, they deform) let dry and give it a try, also check the end of the metal rod and where it connects for contamination.
Posted on May 31, 2007
SOURCE: toner sensor problems
Hi i have the solucion a error of sensor black oki c3100. For two times i have the problem and a long time study the problem. it´s the solucion. Because i spanish the solution is in spanish languaje.
Desmontar la tapa semitransparente redonda del lateral.
El sensor lleva un iman incorporado que dice a la impresora cuando el toner se a agotado. El polvo de impresion lleva impurezas o las ponen a proposito y hacen que el iman no pueda levantar la leva que hace contanto con el sensor. Con un destornillador limpiar las impurezas que estan pegadas al iman por dentro del toner. Cerrar y listo. YA FUNCIONA JAJAJAJAJAJAJAJA.
Posted on Apr 25, 2008
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
  • 154 Answers
SOURCE: OKI 4550 fax
try to boot the front cover and clean the glass over the lens
Posted on Apr 20, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
Incoming faxes have dark bands accross the page. The bands are 1/4" wide and spaced about 1 1/2 " apart.
Sounds like it needs a new drum. You'll have to replace the toner at the same time.
Oct 14, 2010 | OKIFAX 5650 Plain Paper LED Fax
How do you change (where is it) the drum in the Okifax 5650?
rwhen you replace the toner youare putting it in the drum cartridge.the whole black unit gets replaced.lift it up to remove.when you replace it also install a new toner cartridge the drum resevoir will be empty when
new it will need a new toner cart. to fill it now you need to reset the drum counter.push select function
button,to the right number 8 or 9 says counter display
push it,screen will will say drum count reset? push yes arrow screen will say are you sure? push yes
tada! if it now says replace toner open the white cover
over the drum then reclose it a motor will run for about 30 seconds its adding the new toner to the
resevoir you may need to do this about 3 times or until add toner message goes away
Apr 20, 2010 | OKIFAX 5650 Plain Paper LED Fax
Change drum soon warning will not go away. Changed drum and toner
You may need to reset some sort of timer or counter. This kind of information can be found in the owners manual (aka users guide).
1 Wait until the time, date, and answering mode appear on
the display. Then press the Select Function key.
2 Press the 7/Counter Display One-Touch key. The display
shows DRUM COUNT.
3 Press the Yes § key to clear the image drum unit counter.
4 Press the Select Function key to finish.
Feb 05, 2010 | OKIFAX 5650 Plain Paper LED Fax
All our incoming faxes are faded although there is sufficient toner. The heads have also been cleaned and the machine has been cleaned electronically.
Your saying the heads have been cleaned but that points towards an inkjet MFP, if it is a laser MFP, take the toner/drum assy out and shake it hard.. the toner may have settled in storage and may be causing the problems.
Oct 16, 2009 | OKIFAX 5650 Plain Paper LED Fax
FAX MACHINE NOT PRINTING CONFIRMATION PAGE
How do you get a confirmtion page after faxing on a Canon 3235i imagerunneer
Sep 08, 2009 | OKIFAX 5650 Plain Paper LED Fax
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
WORKCENTRE PE220 - How do I print reports from the fax? and I want to set it up to do automatically, but I also need to look at a certain day, to see if a fax went through. Thanks
Hope this helps.
  1. Press the [Menu] button on the Control Panel until 'Reports' is displayed on the top line of the Display Screen.
  2. Press the [Left] or [Right] arrow button until one of the following reports is displayed, and then press the [Enter] button to print the report.
Report / List Description Phonebook List This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers.
NOTE: This list can also be printed by pressing the Phonebook button on the Control Panel.
Sent Fax Report This report shows information on recently sent faxes. System Data List This list shows the status of the user-selectable options. This list can be printed to confirm any modifications to settings that have been modified. Scheduled Job Information This list shows the documents currently stored for Delayed faxes. The list shows the starting time of the Delayed fax. Message Confirmation This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job. Junk Fax Number List This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID. Multi-communication Report This report is automatically printed after sending documents from more than one location. Power Failure Report This report is automatically printed when power is restored after a power failure, if any data loss occurs due to the power failure. elem_1_spacer.gif
Jul 23, 2008 | Xerox Office Equipment & Supplies
Check drum cartridge
You need to clean the drum surface as well the charger roller. Removing the paper jammed can caused the surface get the dirty by toner split.
May 13, 2008 | OKIFAX 5650 Plain Paper LED Fax
OKI 5550mfp Fax Problems
error 209 - Media Table Download Failure MediaTable Download to PU failed. Reboot.
CU firmware detected an anomaly in behavior in PU (including a violation of communication protocol between CU and PU).
are you suing unusual sized paper?
Feb 19, 2008 | OKI C5550N Multifunction Printer - Color...
OKIFAX 5650 Plain Paper LED Fax Logo
225 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
