My hp laptop will not boot up
When I try to turn on my laptop the lights come on but the computer never boots up the screen stays black, it sounds like it is going to try and start but then stops after a few seconds the lights blink the go off does anyone have any ideas how to fix the problem please let me know.
    President:
  • 1,902 Answers
Check the power supply for power. Replace if necessary. Also check the motherboard for proper operation. If no fans come on or only come on for a few seconds then you have a bad motherboard
Posted on Feb 14, 2009
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: laptop won't boot
Hi Connie,
This problem usually occurs if you have faulty RAM (memory)module or it may only need to be reseated to make proper electrical connection.
On the bottom of the laptop there are one or two panels, under one of these panels will be the memory module/s, you need to remove the screw/s securing the panel to reveal the memory. The memory modules are secured with spring loaded catches on the sides of the module, apply pressure to the side of the caches to release the memory module, remove and insert it a few times so it will make proper electrical connection.
Reboot youe laptop and if the laptop still does not work then the memory module most likely is faulty and needs to be replaced.
Posted on Dec 27, 2008
TimeDefensiv
  • 746 Answers
SOURCE: my IBM think pad does
There are two possiblities, first is your data cable it may damage so you need to change it or your data cable not plugged properly so check it. Secondly, you need to reset your boot order to resolve your issue.
Thanks & Best of Luck
Posted on Mar 09, 2011
bendarden
  • 984 Answers
SOURCE: G42-415DX laptop - will not
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
I suggest that you click on the following link to retrieve the HP G42-415DX maintenance and technical manual: Free Maintenance Download
All the best
Ben
Posted on Sep 16, 2011
Why is my Hp Dv7 Laptop not booting up?
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
May 05, 2013 | HP Pavilion dv7-1130us laptop
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Black screen with cap lights on no boot and no bios
Can you get to safe mode? Usually F8 at boot will let you go to safe mode. It sounds as if it is not getting that far in the boot up. Try removing the hard drive and attempt boot up. If still nothing on screen it may be the motherboard or a power problem.
Apr 22, 2010 | Dell Inspiron 1521 Laptop
My laptop screen is black. All light across the
Do you see the BIOS boot up phase, which is the bit in the beginning of booting the computer where you see DOS like white text on a black background?
If you do, there is a good chance that your problem is as simple as a Windows configuration issue. If not, you may have a short in the wires that connect the screen to the motherboard.
The first thing to try is to connect the computer to an external monitor and see if it will display.
Next, try booting in safe mode.
Then try booting from a CD.
It is possible to replace laptop screens, but it is usually not worth it.
Dec 02, 2009 | HP Computers & Internet
My hp pavilion dv2000 laptop wont work it shows all the blue lights and trys to boot up when i turn it on but the screen is still black ,then it beeps and you cant hear it much but the screen stays the...
To verify that your laptop is function and the monitor is now. Try plugging your laptop into a regular computer monitor. If the computer turns on and displays an image on the secondary screen, then you'll need to look into having your laptop screen repaired.
This could be either that your screen has failed, or has just become disconnected somehow from the screen to the laptop motherboard on the inside of the unit.
Nov 26, 2009 | Dell Latitude D600 Notebook
My computer will not boot up Acer 5050 all the lights com on but it never boots the screen stays black. it will not turn off unless you remove the battery.
If you have a VGA cable and a monitor, attempt to plug this into a monitor to verify that the laptop will not boot into your OS (Windows generally). If it does end up booting into your OS, then it sounds like your LCD has died or become unplugged inside the laptop.
Nov 25, 2009 | Acer Aspire 5050-3242 Notebook
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Problems with my laptop
I think it has to do with your video cardsettings.I suggest u should get knoppix live cd which is downloadable free from the net.You then try to boot your computer using knoppix cd by changing your boot options to booting from cd.You enter the boot options by pressing down one of the function keys depending on your computer make.If u are able to boot in to knoppix you can access your video card and then resety it.
Jul 14, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
342 people viewed this question
David Payne
David Payne
