Question about Gevalia CM-500 12 Cup Coffee Maker
Coffee takes forever to brew
Just got my cm500 coffee pot today went to go make my first cup of coffee and it took 1 hour and 30 min to brew the 6 cups I wanted its a 12 cup coffee maker is this the slowest coffee maker on the planet or did I get a dud or do something wrong. Coffee when finished brewing tasted great.
  • stonestn Feb 14, 2009
    yesterday was using the gevalia coca rasberry coffee pre ground (did not grind it myself) this morning made a regular pot of eight o clock coffee that I ground myself 6 cups took approx 8 min so you were 100% correct pierre wierd that gevalia is grinding there pre ground to fine for their coffee maker but thanks for your help and I will always grind my coffee from now on :)
  • 2,039 Answers
Normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
  • pierre laplante Feb 15, 2009
    excuse me im happy that its ok now but it should have been a fixya thank you pierre
  • jokitt475 Sep 11, 2011
    We just fixed our coffee machine! The one way check valve located in the water intake line was blocked by a small bug which shut the line enough to block the water and the heater would over heat the small amount going though causing long coffee making sessions and substantial burn off loss. So check the line by removing the bottom plate screws (5) I think and pinching out the check valve from the orange line. Clean and replace, very simple process! Works great now.
My Mr. Coffee is taking over an hour to brew a pot of coffee
Run a half a pot of vinegar through it then 2 or 3 pots of water. It's from lime and calcium deposits.
Nov 05, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
My machine doesn't brew - the water doesn't flow through: why?
i have a 12 cup programmable cuasinart coffee pot sometimes when i turn it on it will brew right away and sometimes it takes forever to brew. what could be the problem?
Nov 13, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Grx Bunn coffee brewer will not brew. I've followed all directions carefully. I've waited almost 30 min for it to heat up I've added more water and still nothing. Now I have been waiting for about an hour...
It sounds like the tank isn't full. It takes 2 full decanters of water to fill the tank in the bank. After pouring in 10 cups of water, close the lid and wait 3 min. Then open up the lid and pour in another 10 cups of water and close the lid. Then turn the vacation switch on and wait 15 min. Now you are ready to brew coffee. Place your grounds and filter in the funnel basket and pour in 4-10 cups of cold water and place decanter on warmer plate. Close the lid and in 3 min you will have a pot of coffee. If this doesn't happen, please call 800-352-2866 and we will be happy to assist you.
Jun 17, 2010 | Bunn GRX-B
When I put 12 cups of water in the container, only 8 cups brew. Also, it takes 30-40 min. I ran vinegar through it twice and am getting the same results.
the coils are super heating, and condensation of your water is vanishing faster than it's brewing. It sounds like your coffee pot is ready to go to mr coffee heaven
Aug 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Dec 17, 2008 | Faberware 10-22 Cup Coffee Urn
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
1,093 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Andrew Taylor
Andrew Taylor
Kolbrun...
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
