Question about Yamaha Audio Players & Recorders
My yamaha receiver LCD screen dose lit when power up
What can i do to fix the problem?
    Genius:
  • 1,175 Answers
Is it an RX series receiver?
I've repaired 2 of these recently with the same problem you have.
There's a very small 14 volt bulb that fits into the hood on the back of the LCD display.
It's about 0.15 inches in diameter and will need to be spliced into the existing two pin cable ( after you cut out the bad bulb)
Posted on Feb 16, 2009
Yamaha HTR-3063 AV Receiver has stopped working. I turned it on and the lcd screen scrambled, then sound cut out. Can I fix this?
Have you tried switching the unit on with no cables or speakers connected and yes the unit can be repaired no problem.
Jun 15, 2016 | Yamaha Audio Players & Recorders
PSR e423. Why does it have a blank screen and no sound?
Blank screen and no sound, can occur because of damage to the power supply circuit in the PSR-E423.
Circuit power supply is still working but the voltage is not sufficient. This is indicated by a lit LCD screen but does not appear any character, and the sound did not exist. It is a matter of hardwares, so it can not be reset by software.
Should be fixed to the experts.
Do you use the original adapter? Also check the voltage.
Maybe, it is not known why, a voltage adapter has been dropped.
Aug 25, 2015 | Yamaha Music
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
The sceen is black but wen u press the power
Stefieanne, The long, thin, "cold-cathode-fluorescent-lamps" are not staying lit anymore. Unit's "switch-mode-power-supply/CCFL inverter supply will need REFURBISHMENT to restore proper operation. SOFTWARE WON"T HELP YOU!!!!! Visit all links you find while doing some reading in my fixya profile to help you in the big decision you will need to make on what you will do with this "black" or "blank n black" screen ccfl back-lit lcd monitor. Do you have soldering pencil of about 35 watts and some solder and pliers and screwdrivers and even a digital voltmeter. Contract out the work $35 to $90 Tell us what your intentions are. 12fixlouie
Mar 21, 2010 | Neovo AG E-17A 17'' LCD Monitor
I dont get streo sound from my front left and
On the front LCD display of the receiver their is a small button for speakers A & B, make sure they are both lit. If they are, post a comment and I will help you troubleshoot further
Jun 29, 2009 | Audio Players & Recorders
Samsung monitor troubleshooting
my computer power is on and my computer also start quick but the screen of the this moniter start after 15min to 30mins this problem how to solve.
Aug 23, 2008 | Samsung SyncMaster 540N 15" LCD Monitor
LCD Screen dead
This may be a dumb idea... but did you accidentally turn the screen off? Don't ask how I know this...
Dec 26, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Dec 23, 2007 | Yamaha RX-V795 Receiver
Red dot
That dot represent lit (stuck) red sub-pixel and if it only one that is not considerable as failure due to dead pixel warranty but you can try to solve this problem with software called screen fix. It possible that during exploitation that red dot dissapear.
Good luck
Jul 01, 2006 | Samsung SyncMaster 510N 15" LCD Monitor
160 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
