Question about Canon PowerShot A75 Digital Camera
The screen doesn't show any image focused at rather it shows greyish blinking patterns on the screen My camera is Power Shot A400
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, remove the battery and let it sit for a while in that condition. This is to revert settings to factory default. Additionally, determine if your particular model has a coin size Lithium battery for memory back-up. If so, remove this likewise.
Should the above be not corrective, then it could be a number of possibilities. To determine which, the unit has to be opened up for a look & see as well as voltage checks. Fault could be:
  • LCD screen;
  • mainboard/LCD interface;
  • worst case scenario, faulty CCD lens (least likely).
Unfortunately, this type of faults could not be corrected with simple button/key pushing and would require electronics works/parts replacement. If you would factor in the cost of repair, the downtime and efforts needed to effect a repair, it may all boil down to no longer economically reasonable. This being the case, you may want to re-evaluate your options and consider replacing the camera.
Good luck and thank you for using FixYa.
Posted on Feb 14, 2009
  • 10,594 Answers
Please reset camera and check live view result.
If problem still exist, CCD Imager is suspected.
  • 744 Answers
 hi.... it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819...
thank u!!!
Canon Power Shot A400. Doen't show image on screen
It is CCD Imager problem. CCD Imager will be replaced to get live view to take picture.
Feb 14, 2009 | Cameras
Canon power shot A400
this is a BAD CCD problem thousands are facing dont worry Canon will repair it free of charge even if u are out of warranty and not on list , just call or contact CANON in phillipines see this PLS RATE ME FIXYA for help
http://support-asia.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
pls contact canon in ur region they will do the rest !!
Feb 14, 2009 | Canon PowerShot A430 Digital Camera
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Vibration hand image showing
Hand sign/ image means "manual focus" it doesn't mean anti-vibration. Press Focus button to cancel manual focus and ON the auto-focus. Hand symbol will disappear.
Jul 18, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Fuji S2 problem
Err after a shot usually means bad AAA batteries. Change to alcaline or NiMH rechargable.
Dec 27, 2007 | Fuji FinePix S2 Pro Digital Camera
Canan powerhot a400 mallfunctions
Upper Indicator
" Green: Metering complete (two beeps sound)
" Orange: Flash will fire
" Blinking Orange: Camera shake warning / Insufficient exposure
Lower Indicator
" Yellow: Macro Mode / Manual Focus
" Blinking Yellow: Focusing difficulty* (single beep sounds)
* When the indicator blinks yellow, lock the focus before shooting.
lcd_focus_indicators_a70.gif The AF frame appears as follows when the LCD monitor is on. " Green: Metering complete
" Yellow: Focusing difficulty (When AiAF is turned on.)
Dec 06, 2006 | Canon PowerShot A400 Digital Camera
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Picture ripples
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Picture ripples
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot A75 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
