Question about Toshiba Satellite A100-S8111TD Notebook
Won't power on
I have a toshiba satellite a100. no power/ blank scree. removed battery and directly plugged in. no power/ connected battery and plug/ battery led ok/ still no power. what can I do next?
  • Toshiba Master
  • 13,433 Answers
Hey,
You can attempt to remove the ram from the computer, start with no ram, reattach one ram and try starting up again.
you may have a hardware problem that might require repairs. I suggest you contact toshiba service for repairs.
there are not many things that you can attempt at home. replaceing of parts is one.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 16, 2009
Problem with Toshiba laptop
It stays on with Battery? Has the AC jack been damaged due to pulling on the cord while plugged in? Have you tried another cord/charger with the EXACT same power specs? Does the cord/charger charge the Battery? Charge LED lights? It sounds like a Graphics Adapter? If you connect to a external monitor is it the same. Your question/statement indicates multiple issues. 1 , Power, 2, Graphics. Can you clarify "color blank"?
May 22, 2013 | Toshiba Satellite PSLD8U-00G001 L355-S7831...
Toshiba Satellite A100-233 is not powering up
Welcome to Fixya.
Here are the things that you can try for troubleshooting a "No power" issue :
  • Remove all connections from the laptop (including all USB cords, ac adapter)
  • Carefully remove the battery and set it aside
  • Press and hold down on the power button for at least 10 seconds
  • Plug the AC adapter back (without the battery) and test the machine
  • If it works,then try to power it again with the battery this time
For your convenience, here's the link for Toshiba's support in case you need to contact them for warranty repair options :
Toshiba Support
Hope this helps, Thanks for using Fixya.
Apr 28, 2011 | Computers & Internet
I have changed toshiba satellite a100-233 keyboard. now locked to bios password. managed to short c88 solders but still screen appears asking for password. wot to do..?
Firstly power down the system. You will need to unplug the CMOS battery from your motherboard for approx 5-10 minutes, then plug it back in. The CMOS battery looks something like this:
Feb 09, 2011 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite A100 dead. orange steady battery light with mains connected and power button lights shift key and 2 function lights - that's it.
It will turn GREEN when the battery is fully-charged.
Is there a problem with the battery not accepting a charge?
Remove the battery, to see if the computer will start without it.
Do these 2 lights just "blink" once, and then go out?
Does a "power" button stay lit?
Have you hired a professional computer technician to trouble-shoot?
Sep 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
The system is not starting.
This could be due to any number of issues,
Try this first.. try booting it off just the battery...
any change?
If not , then remove the battery, remove the power cord, press and hold the power button for 30 seconds..
Then, plug just the power cord back in, no usb devices, or anything else plugged into the computer
With just the power cord plugged in, now try to power it up, any change.
Apr 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite laptop will not power on. If you plug the power cord in the power indicator lights come on, but when you depress the start button the whole computer dies. The battery does not charge when...
firstly check your power voltae from your transfomer, to the laptop...if its normal..then try to get the same type of battery and check if it is a problem...if all are doing fine..then your cmos battery , change it..last options are with the memory ram, and processors...step by step..it should solve your problem
Oct 20, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Will not power up
hi,
try without battery if not powering on this might be the issue with the motherboard so contact the customer support.
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba a100 laptop
Definitely try without the battery. These models are known to have a "short" problem, usually with the palm rest, which causes this failure, although it usually is more sporatic, and doesn't happen 100% of the time.
Also, can you remove all but 1 piece of memory.
Good luck, and let us know what happens.
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
