Question about Zebra Eltron P310 Thermal Printer
Keeps printing on 1 spot
The test print will print 2 cards fine, but on the 3rd card, it feeds to the print head and keeps printing at the start of the card and keeps moving bach and forth.
    Scholar:
  • 115 Answers
I am a bit unlear of the QUestion Here.
But let me say it sounds as if it it tring to print in color.
The back and forth motion is what tells me that.
Posted on May 28, 2009
  • James Williams
    James Williams Jul 18, 2009
    Could also be in Cleaning mode?
I have Zebra P330i printer, have done the cleaning using short and long cards. Display shows "Ready". On printing using color ribbon, the messages (Printing Yellow, Printing Magenta...)appear on...
Knowing that you were able to complete the proper cleaning procedure using the short and long cards, and the printer is on ready status, try to change the ribbon and test. Make sure the card is properly inserted with the magnetic stripe on the top facing down. Also make sure that the ribbon is properly loaded. There should be an instruction on the cover for its proper orientation.
If it still does not print, make sure your configuration on the printer is set to the proper type of cards HICO or LOCO and the ribbon type is properly set to YMCKO for color. Also, check if you have enabled mag stripe encoding or if you don't need to have it enabled. Enabling means that the printer will check for the mag stripe if its good or bad. If bad the printer will reject the card.
Do a self test print by following the below. 1. Set the printer's power switch (on the back of the printer) to the OFF ( O ) position. 2. While pressing the Printer's front panel button (next to the LCD display panel), switch the printer ON ( ' ). 3. Hold the panel button until the LCD display panel reads "SELF TEST". 4. Release the panel button, and the test card will print
If no prints, observed for any mechanical errors on the printer. Normally mechanical errors are detected by the printer with corresponding error message.
If none of the above works then you might have a print head problem. You may attempt to clean it by following below. Else if it does not help then have your print head replaced.
A cleaning using the Cleaning Cards usually suffices. However, a separate Print Head cleaning can remove more stubborn deposits when print anomalies persist. To avoid deposits, only use foam-tipped swabs. 1. Place the printer power switch in the OFF ( O ) position. 2. Open the Main Cover, release the Print Head Carriage, and remove the ribbon. Leave the Print Head Carriage in its raised position. (For details, see Chapter 2.) 3. Clean Print Head by moving an alcohol-moistened swab tip side-to-side across the Print Head elements. Only use moderate force. To re-order swabs, please refer to the Media List on the Windows Drivers and User Documentation CD supplied with this printer. 4. The swabs can also be used in a similar manner to clean the optional magnetic encoding head.
Jul 12, 2011 | Zebra P330i Thermal Card Printer
BROTHER DCP-560CN Not printing enough yellow
This can happen to cartridges with attached print heads such as HP, Lexmark or Dell. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
How can I get dried ink out of my inkjet print head so I can print again? Place the clogged cartridge in about 1/4 - 1/2 inch of warm water for a few minutes. When ink starts to slowly leak out take the cartridge out of the water and dry it using a soft cloth to "Q-tip." Then place it back in your printer and run the print head cleaning utility that comes with your printer software. You may have to run this 2-4 times before printing quality is reestablished. If your print head is destroyed, as can happen, you will have to buy a cartridge and refill that cartridge before it is fully empty
Feb 19, 2010 | Brother MFC 420CN All-In-One InkJet...
I have a blank line across all the cards
If the line is across the card from end to end on the long side in the same spot every time, then try cleaning the printhead. If it is still there then you most likely need a new printhead.
Jun 26, 2009 | Zebra P330i Thermal Card Printer
Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
May 12, 2009 | Fargo 4250 Thermal Printer
Clean prinnter massage
The Zebra printer displays the Clean Printer message when the printer prints a 1000 cards.
This is to maintain printer and ensure good print quality.
The way to clear the message is to get cleaning cards and run a cleaning routine.
The CD that comes with the printer will run a video showing how to run the cleaning cards through the printer. Printer needs 2 unique cleaning cards (1 short & 1 Long)
Feb 01, 2009 | Zebra P330i Thermal Card Printer
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Credit Card Printer P250 prints too small
    I had a similar problem ... printer printing receipt just like when printer test conducted. I turned printer off, pressed/held paper feed button, turned on, let test run, then shut off. This didn't work ... so I disconnected terminal cable from printer (printer turned off) and reconnected. Printer now works fine.
    Dec 05, 2008 | VeriFone 250 Matrix Printer
    Zebra P330i
    we have the same problem with our 330i !!
    I updated the firmware to V1.16.11 and the printer drivers as well, then I started the cleaning process.
    The printer has printed only 337 cards, so it is rather new.
    All monocolor printed cards are ok (black, gold,...), but not even one 4color card.
    It looks like the sync of the colorribbon does not work properly.
    Is there a possibilty to check the sensors or are perhaps informations about the sensors on the cardtest-card ?
    Thank you for any help !
    Felix
    Austria / Europe
    Feb 06, 2008 | Zebra P330i Thermal Card Printer
    Only prints business cards correctly on plain paper, but not on the card stock.
    I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
    Oct 21, 2007 | HP PSC 1410v All-in-One Printer
    Can't Print on Card
    I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
    Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
    To access the rollers, remove the scanner plate:
    1. Disconnect power, USB, and phone cables.
    2. Open up the scanner sheet feeder by tilting it left.
    3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
    4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
    4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
    5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
    6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
    Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
    Zebra Eltron P310 Thermal Printer Logo
    134 people viewed this question
    Top Zebra Office Equipment & Supplies Experts
    Dave Busselle
    Level 1 Expert
    Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
