Question about Samsung WF338AAB 4.0 cu. ft. Front Load Steam Washer
How close can the samsung washer wf338aab be to a wall
I really need to know when you are installing the washer how close can the back of the washer be to the wall
    President:
  • 1,902 Answers
Completely against the wall but it is recommned to be atlest 3 inches off the wall
Posted on Feb 14, 2009
H20 symbol on display of hotpoint wf 860 washing machine
Pull off your washer mains cord from the wall. Turn off your wall faucet,, the valve on wall which allows water into the washer. (h2o means your washer is not receiving the most importing thing - water). Disconnect the pipes of the water from the wall. Check by opening the wall valve to see if the water flow is gud. Next fit back carefully. Then unscrew the other end of the hose/hoses at the entry point of your washer - remove the fine filters and clean out with an old tooth brush; clean inside the opening of inlet valve too carefully, check. Now re-fit the filters carefully and screw back the hoses. You are done now. It is advisable to close the wall valve when your washing is done, takes pressure off the machine valve.
Pl click if helped.....
Apr 05, 2013 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wt540 washer wont fill
Pl click if helped......................
Apr 02, 2013 | Washing Machines
No water check supply
What does mean error h2o when i start to spinn
Pull off your washer mains cord from the wall. Turn off your wall faucet, the valve on wall which allows water into the washer. (h2o means your washer is not receiving the most importing thing - water). Disconnect the pipes of the water from the wall. Check by opening the wall valve to see if the water flow is gud. Next fit back carefully. Then unscrew the other end of the hose/hoses at the entry point of your washer - remove the fine filters and clean out with an old tooth brush; clean inside the opening of inlet valve too carefully, check. Now re-fit the filters carefully and screw back the hoses. You are done now. It is advisable to close the wall valve when your washing is done, takes pressure off the machine valve.
Mar 11, 2013 | Washing Machines
Reset Samsung washer
try unplugging from the wall for 30 seconds and plugging it back in
Oct 22, 2017 | Washing Machines
When machine cuts off water still runs in
You probably have a leaking solenoid. A solenoid is a valve that is either opened or closed. You have one for the hot water line, and one for the cold water line. The hoses from the wall go to the solenoid valves at the back of the machine. The machine tells them when to open and close based on what cycle you tell the machine to perform.
To figure which one is leaking by, shut off one of the water supplies (hot or cold) at the wall where your hoses connect. Wait a bit and see if the water continues to rise. You may have to mark the level in the tub with a pencil, or grease pencil to see if it is rising or not. If it is rising, that's the leaking side. If not, close the open valve at the wall, and open the other valve. Continue to observe to see if the water level rises (it should). Once you have determined which one is leaking by, disconnect (unplug) the washer, close the water valves, and follow the hose of the leaking side down to the washer. Where the hose screws on to the washer is the solenoid in question. Disconnect the hose, and catch the water in a pot or a bucket. Gain access to the solenoid (usually by taking the back off of the washer). Take careful notes as to how the wiring connects so reassembly isn't an issue. I make sketches showing where each wire goes, what color it is and so forth, and that's real handy. Remove the solenoid. Take the solenoid with you to an appliance parts supply house and get a replacement. The installation process is the reverse of the removal process.
Hope that this helps. Best regards, --W/D--
Jan 29, 2011 | Amana 3.2 cu. ft. Top-Load Washer
The cold water will not shut off, even when the machine is off
Hi, W/D here.
Jan 24, 2011 | Maytag Neptune MAH6500A Front Load Washer
Washer door leaks
The front baffle/boot will likely need replaced. You can do this yourself but it takes some patience. You can order the part, list model #, at 888-321-3107. The procedure is as follows:'
1. Tilt washer, back against wall.
2. Remove wire spring with needle nose plyers. The spring is located at outside perimeter, under lip, of baffle.
3. Peel baffle from front panel.
4. Remove clamp from the outer tub lip. Look closely and you should find a large hose clamp. Use small socket wrench to loosen.
5. Install in reverse order. Be careful and take your time.
Rich
Western Appliance Repair
Washer Repair
Sep 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am installing a Kenmore dishwasher model 13743. I have direct wired the washer?s terminal box wires to the wall power via a BX wire and the washer doesn?t respond. None of the panel buttons are...
next step to check the door switch...the door must close and the switches on the door must close to send power to the control...let me know
Sep 19, 2009 | Dishwashers
Series 70 kenmore elite washing machine
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Let me know if it worked..
Oct 17, 2007 | Kenmore 22422 Top Load Washer
Samsung WF338AAB 4.0 cu. ft. Front Load Steam Washer Logo
203 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
