Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Motor sounds like it is straining '
Purchased my maytag q 300 about three years ago. Never used it much until recently. For the first two weeks that we used it on a regular basis it was great, two weeks later I can now here a humming noise that sounds like it is straining. Almost like something is stuck, but the jets are working fine. The straining noise is coming from the bottom of the machine. Any suggestions besides just getting a new machine.
  • 423 Answers
When you get a chance, please post the whole model number of your Maytag dishwasher here.
Because you are still getting clean dishes, you probably have debris (a bone or fruit pit) that has gotten down to the pump/impeller or the chopper area.
Remove the lower spray arm, remove the filter/sump assembly and clean everything out. With a flash light, inspect the whole sump area for debris. I bet you will find stuff there (beware of broken glass!) and when you re-assemble, the noise will ne normal.
Good Luck! Please post back what you find, OK?
Posted on Apr 10, 2009
My Maytag model number MEY18F7E will turn on for about 10 seconds then quit and trip the breaker. It just started doing this about a week ago. Has been working fine since I purchased the home several years...
Sounds like you have a bad compressor, something is either shorted out, or drawing too much power causing your breaker to trip.
Is this a window unit, or a ductless unit?
Aug 23, 2013 | Maytag Heating & Cooling
MAYTAG BRAVOS QUIET 300 VERY LOUD WHEN IN SPIN CYCLE
spinout bearing bad if noisey in spin only whole tub must be repaired
Feb 16, 2013 | Maytag Bravos 3.8 Cu. Ft. Washer
I have an E1060 drop in. The unit was purchased three years ago, but major delay in construction. Installed a couple months ago, all was fine. Have yet to cook on this grill. Two weeks ago, went to use,...
Dan, did you check the circuitry and relays to the motor, as was suggested on March 29th? If the motor can't get power it won't work. It seems, that this may be the problem, since you took the motor apart and there were no broken gears and all other electrical devices work. The other resolution was to contact R.H.Peterson Company, the manufacturer for more information, if all else failed.
Mar 31, 2011 | Fire Magic Echelon E1060s2E1P51 Stainless...
Should the compressor be going fut fut fut? I got mine out of a box new after keeping it unused for three years. It makes a fut fut fut sound rather than a continuous pressure release. Is this normal?
I have heard some belt drive compressors make that fut fut fut sound you describe, Its not a problem in my book as long as the pressure builds and the motor is not straining. I have even heard that sound come out of direct drive compressors, so I don't think you have a problem here.
Jan 22, 2011 | Mammoth 300 PSI Air Compressor 12 Volt
Three weeks ago purchased a Vizio xvt423sv 42".
There are lots of problems. The best thing to do is have it replaced completely while under warranty.
Jan 09, 2011 | Vizio XVT423SV 42 in. HDTV-Ready LCD TV
2002 caravan trans. no 3 or 4 gear
replace the input and output speed sensors
May 28, 2009 | 2002 Dodge Caravan
Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
MAH3000AWW
Replace both the main control board and the wax motor. This sounds like a computer chip malfunction
As far as the squeak, make sure it is not the bearing located at the back of the tub under the large pulley.
Jan 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
153 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
