Question about Samsung CLP-510 Laser Printer
Printer will not print
Samsung CLP 610nd printer cartridges were refilled and printer worked briefly, now red light flashes and tone low is message. Can not get printer to work at this time. originally by pressing the button near ''menu'' button it would show ''continue'' and you hit ok and printer would work. Have printed about 500 pages since I refilled the toner cartridges.....any suggestions.......... engle.dean@yahoo.com
If you refiller the tone cartriges yourself or by someone else then mabye the chips need to be reset. An easier way is to tape over the three copper pins on the right side then turn the printer off and when turning on hold the menu key until it says uncheck consumables mode. Unfortunatly in this mode you will not know when you are out of toner until it doesn't print right but it can get you thru in a pinch.
Posted on Mar 09, 2009
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Status light goes green when power on, but then turns red and cannot print - replaced toner cartridge- not sure what the reason for the red error light is?
You have to reset your printer with a module or replace chip when you refill toner cartridges.
www.nakshatraworld.com
Jan 07, 2010 | Samsung CLP 300 Laser Printer
Toner is exhausted!! insert a new toner; this message appears while printing the page; i m talking about samsung ML1640. i have refilled the toner cartridge; but still that message appears; wat i can do...
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Nov 04, 2009 | Samsung ML-1640 Monochrome Laser Printer
3 month old machine, low print usage, showed "Replace Toner". Replaced with Samsung cartridge but still showing Toner Empty message. Replaced with another new Samsung toner, but message will not go away....
you need to reset printer thorught software
We have Zero cost solution for samsung -scx-4300, ml-2240,ML
Nov 02, 2009 | Samsung SCX-4300 Monochrome Laser...
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
New yellow toner not fitting properly
try to install the cartridge again and see if it can print.or u can reinstall the printer drivers. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Samsung CLP 300 Laser Printer
I have a samsung ml 2851 nd that won't print, and says the toner cartridge is low - I replaced with cartridge 209 (which office max said would work) and it still flashes the red light and says there is...
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Apr 23, 2009 | Samsung ML-2851ND Laser Printer
Can't print just black when out of color with Samsung CLP-300
its not possible till you get that rec colour refilled in your colour cartridge or replace the colour cartridge.so you cannot print black as the printer is not been able to end its cycle as the cycle is getting break at the colour cartridge.its very common problem faced by many users but no other option except replacing or refilling the cartridge.
thanks.
Dec 14, 2008 | Samsung CLP 300 Laser Printer
Samsung clp 510
usually happens when the NIC card goes bad, may need to replace.
first try resetting the printer, look in your manual
Aug 25, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
163 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
