Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
HELP!! PT-53TW53G Panasonic Projection wont power on
Ok, today i was watching t.v and all of a sudden it turns off. When i press the power button the t.v tries to power up but then turns off very quickly. Theres no picture and no sound at all. The blinking red light on the front blinks once every 5 seconds. Please help!! What could be wrong?
  • carlos34774 Feb 14, 2009
    It does not blink 5 times. The red light blinks only one time then 5 seconds later it blinks one time. and it keeps doing this pattern over and over again.
    President:
  • 1,902 Answers
5 blinks means your lamp is bad. You can order the part here.http://promotions.partstore.com/Brand-Landing-Pages/Sony/Sony-A.html?s=overture&OVRAW=Sony%20Part&OVKEY=sony%20part&OVMTC=standard&OVADID=31511369012&OVKWID=212386201512
Posted on Feb 14, 2009
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Panasonic PT-53TW53G coverage wont move the blue color? I DON'T KNOW THE PROBLEM. I JUST REPLACE THE IC'S. pLEASE HELP
Did you check the six 2.2 ohm 2watt resistors? Usually your model will have at least one blown when the ICs fail
Nov 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
TV not turning on..blinking red on power
the blinking pwer indicator is an error code. How many times does it blink?
May 13, 2009 | Televison & Video
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Oct 31, 2008 | Televison & Video
No power
I had the same problem with my t.v. and I had a t.v. repair shop tell me I need to replace the High Voltage Power Supply and the Deflection Circuit.
Jul 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
No Audio or Video, blinking power light
Did you ever find anything out about this? I have a pt-53tw53g with the exact same problem, and I've been unable to find out what the three flashes means.
Aug 02, 2006 | Panasonic PT-56TW53 56" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
252 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
