Question about Microsoft Windows XP Professional Upgrade Version OEM for PC
How to upgrade from FAt32 to NFTS?
To upgrade system files on xp computer to NFTS
    President:
  • Microsoft Master
  • 1,314 Answers
Here are the complete step by step instructions from microsoft.
Thanks and please remember to rate both these questions as fixya.
Posted on Feb 14, 2009
I bought a 16GB DenDyne multi-function USB Digital Assistant and my computer is not loading it. It knows the device is there but shows no memory and am unable to copy files on it. I have Windows XP...
Try to format your USB Drive if that is not formatted yet. On your my computer you will see the USB drive right click on it then click reformat after reformat the computer will now recognize the available size of your device. Because if that the first time you to plug in a computer, the computer will not recognize if your USB is NFTS format or a FAT32 format.
Jul 22, 2011 | CenDyne 16GB USB 2.0 Flash Drive (Black)...
I am using Windows XP I tried to reinstall the operating systems and now have it twice under the one partition, how do i delete one of the windows installation to reformat the hard drive?
Its going to be a case of re-installing XP again.
As you go through the process, XP asks you which partition you would like to install onto.
If there's already and installation on the partition, you have to delete that partition.
As you continue through the process, XP will has you if you what kind of file system do you want Fat32 or NFTS. Choose NFTS and go for the full format. That should clear the drive of previous installatiions
Apr 30, 2010 | Microsoft Windows XP Home Edition
HP D9811 monitor freezes and then starts blinking on and off
Since you mentioned that your mouse freezes and your keyboard freezes, I'm pretty sure your problem does not exist in your monitor at all, but in the computer itself.
The first place I would look for a fix is in your video card. Since you started with a 98 machine and upgraded to XP, I'm not sure how that was done. It has been problematic in my experience to run a FAT32 file system under a XP operating system, and in those days it was a common upgrade.
The problem with it was, and is, that the drivers are built for an NTFS file system and FAT32 is on your pc.(maybe)
The first change I would make (well, as a tech, it would be to erase the hard disk and reinstall the os, but let's just talk about the fix here) is to look at the drivers for the video card, and check with the manufacturer of the video card for the most current one.
If that is already the most current, check the file structure to see if it is FAT32; and if so, consider backing up your data and reinstalling the OS under NTFS files structure.
good luck
tony
May 19, 2009 | HP Computers & Internet
My lacie external drive cannot be located even though it is connected to my macbook. i can connect it to a PC with no problem but all tiff files are mac based so cannot open them in the PC. What should I...
Hook your drive back to your PC. Right click on it and check 'properties'. In the box that pops up if it says file system NFTS you are out of luck as that is a non mac compatable file system. If it says FAT32 it should be working on your Mac. If it says NFTS you'll need to transfer the files onto the PC reformat the drive using the LaCie software to FAT32 (the only file system that both Mac and PC can use) then transfer the files back to the external drive. Reformatting erases everything on the drive so don't forget to transfer the files first! I can place Tiff files into Adobe products on my PC so I'm not sure what you mean by Mac format tiff???
May 10, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Hard drive upgrade
It has to have SATA Hard Drive Connector DFHS22FR685, if you have this then I would try to format the hard drive to what your operating system is using, either NFTS or FAT32. The drive may not be properly formated for your system.
Jan 22, 2009 | HP Pavilion dv9000z Notebook
Unable to drag large files over from my computer onto MY BOOK
Fat32 is the predecessor of NTFS. There is no real difference apart from the transfer limitation, which you're experiencing.
Before proceeding, make sure you have backed up everything, you may have put on the drive.
Now, simply right click on the my book external drive in my computer and select format. You should get a popup window...The only thing that really needs to be changed within that window is the filing system (NTFS) and have the option "quick format" selected. Now select 'start' and within a minute or two your drive would have been formatted to NFTS.
Nov 18, 2008 | Western Digital My Book Essential Edition...
Max Hard Drive
There is no max size when it comes to hard drives. Go as big as you want or can get.
Jul 07, 2008 | Compaq Evo N1000C Notebook
There is a fat error on the mp3 player
If you have a MAC you will get that error - unfortunately I cannot help with Macintoshes.
If, however, you are using Windows then I can help you. You need to format your mp3 player to get rid of this message. Your file system is probably NFTS or FAT32, and this player is trying to read it as a FAT. You will need to take a look at the properties of your C: drive, and see if your computer is a FAT32, or an NFTS.
Solution:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jun 25, 2008 | Audio Players & Recorders
Microsoft Windows XP Professional Upgrade Version OEM for PC   Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
