Question about Microsoft Windows XP Professional Upgrade Version OEM for PC
Which course of action should be taken to upgrade file system?
The file system on a windows xp computer fromFAT32 to NTFS
  • Kathleen Bota
    Kathleen Bota May 11, 2010
    hi babystay...
    do you just want to change the file system, or do you also want to re-install windows?
    i just did this on my laptop during a re-install...
    bru*
  • Microsoft Master
  • 2,385 Answers
You need to format selected drive and slect file format NTFS.
Posted on Feb 14, 2009
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Tip
Way to Speed Up Windows Xp by defragmenting disk
Ensure that Windows XP is utilizing the NTFS file system. If you're not sure, here's how to check: First, double-click the My Computer icon, right-click on the C: Drive, then select Properties. Next, examine the File System type; if it says FAT32, then back-up any important data. Next, click Start, click Run, type CMD, and then click OK. At the prompt, type CONVERT C: /FS:NTFS and press the Enter key. This process may take a while; it's important that the computer be uninterrupted and virus-free. The file system used by the boot-able drive will be either FAT32 or NTFS. I highly recommend NTFS for its superior security, reliability, and efficiency with larger disk drives.
on Oct 04, 2010 | Computers & Internet
Windows did not start ,drivers missing
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  7. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer
Mar 03, 2011 | Computers & Internet
Will i be about to use with both my laptop running Windows 7 AND my desktop running Windows XP? is making a seperate folders for each computer enough?
Yes, because boyj Windows xp and windows 7 utilize the NTFS file system. If it was windows 2000 or earlier, they wouldn't, as they would have different file systems. NTFS versus FAT32 for the older operating systems.
Jan 24, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
What is the difference between ntfs & fat
This are the difference between the two.
File Allocation Table (FAT): A file system used by MS-DOS and other Windows-based operating systems to organize and manage files. The file allocation table (FAT) is a data structure that Windows creates when you format a volume by using the FAT or FAT32 file systems. Windows stores information about each file in the FAT so that it can retrieve the file later.
NTFS: An advanced file system that provides performance, security, reliability, and advanced features that are not found in any version of FAT. For example, NTFS guarantees volume consistency by using standard transaction logging and recovery techniques. If a system fails, NTFS uses its log file and checkpoint information to restore the consistency of the file system. In Windows 2000 and Windows XP, NTFS also provides advanced features such as file and folder permissions, encryption, disk quotas, and compression.
Dec 05, 2010 | Computers & Internet
Installing windows xp --------- Plz tell me that what should be the partition of 40gb HDD if u want to install xp.What should be the file system NTFS OR FAT32?is it true that ntfs is bad for HDD
Choose “NTFS” as it is faster and more secure. It is not bad for your HDD. If you don't have any other Hdd you might want to upgrade. They don't make 40gb hdd any more, XP will take about half that when it installed. It really limits what you will be doing with your computer in the near future.
I hope this helps.. Good luck
Oct 23, 2009 | Microsoft Windows XP Professional for PC
Converting Partition to ntfs
goto start 2.Run 3.type cmd 4.type CONVERT volume name or drive letter /FS:NTFS
Oct 19, 2008 | Computers & Internet
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Microsoft Windows XP Professional Upgrade Version OEM for PC   Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
