Question about Panasonic PT-47WX49 47" Rear Projection Television
Red blotches i recently was given a panasonic rear projection tv. the problem is that there is red blotches on the sides. what is wrong and how do i fix it? thanks
    Novelist:
  • 184 Answers
This is phosphur burn and the only solution to this issue is to replace the CRTs(picture tubes) The cost of this, as you can imagine, is quite high and probably not worth doing.
michtech
Posted on Feb 14, 2009
I have a green tint on the screen. covering about 90 percent of the tv. it looks like a block on the bottom right corner. the very top and right side of the tv is fine. its prob about a two inch line that...
If you tried to clean the mirrors or someone else tried, there may be an object on one of the picture tubes. I've seen this happen. In one case I repaired a projection TVwith a piece of black tape across the red tube. It may have left the manufacturing plant this way. Please check and see if a cloth is laying on one of the projection tubes. If not, you have a contaminated picture tube, replace the fluid. Thanks for asking!
Mar 21, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
I have green blotches on my Hitachi 42V710
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 20, 2007 | Hitachi 42V710 42" Rear Projection HDTV
When I cut the TV on the red light flashes 2 times and then the TV cuts off. What is wrong with it? Thanks in advance. lonecatalyst at gmail dot com
On panasonic tv's the flash indicates to the technician what the fault is by the number of flashes it makes. in this case its a power board failure within the set. it needs a workshop to fix it -sorry
Jun 16, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Three inch red dot appears on my Panasonic tv screen. It is an LCD. Can it be fixed? What do you think it is? The dot shows up mostly on the light scenes.
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly.
Sep 20, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Red blotches on screen
Serce this questin using the term "pink bloches" I explained it there.
Oct 10, 2008 | Epson Livingstation LS57P2 57" Rear...
Red blotches
What you possibly have is dust on the green or blue lcd panel inside the optics assembly. Since the red is showing through the dust is not as bad on that lcd panel. I suggest having a service center attempt to clean the optics assembly, although replacement of the assembly may be required, some of the light engines are sealed systems.
Apr 02, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Dark blotches behind the screen
When I had this problem with my 52525 I cleaned the bulb with a lint free cloth. The dark blotches went away.
Dec 28, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Pt-61lcx65-red spots on screen
Check with Panasonic. I have the same issue and was originally told that the optic board needed to be replaced ($1700). I waivered on getting it fixed and spending more than the tv is worth. So I now learned that there is a new fix for the bad optic board and Panasonic is repairing it free of charge. Repair is schedueled for next Friday (Feb 1, 08). I'll report back if it was successful. This repair involes an eprom on the optic board. Hope the sheds new light........
Dec 19, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Red picture in panasonic 60" Rear Projection TV
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 27, 2006 | Philips 60PP9352 60" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
