Question about HP vs15 15"LCD Flat Panel Monitor
Screen wires loose?
My HP laptop started with a few colored lines on the screen, then the amount of them grew and quite a few are there now. But then it fell the short distance from my sofa to the floor. I dont know if that was just the last straw, or if that was a very bad fall, but the screen turned kinda white with tons and tons of the colored lines on it. But the funny thing is that the screen still changes color with the desktop and when i twist the screen to the left it shows the screen until i let go of the screen. That makes me think its just a loose wire, but i need help...
P.S. it works on an external monitor.
  • 40 Answers
That sounds like there are one or more components (eg. coil or capacitors) that are lose inside your screen.
Ther are high frequenzies working in there and sometimes
it happens that some componets vibrate to the point to where
the soldering point breaks down and the component get lose and
there is no longer any contact to it.
Can also be that one or more circuit boards are cracked in there.
Unfortunately i dont think there is much you can do but let a repair and service man look at it unless you are of a technical nature and skilled in soldering.
Posted on Feb 14, 2009
  • HP Master
  • 2,404 Answers
Sounds to me like its the cable going from the lcd to the motherboard. Probably needs to be reseated as long as its not broke from the fall.
My Asus laptop has a pink coloured half screen with a few lines through it too!! it was working normal when i switched it on then all of a sudden it went like this!! whats happened please help!!
This can be one of three problems:
1 - The cable that connects your screen to your laptops motherboard has come loose. If the problem is intermittent or can be rectified by moving the screen / holding the laptop upside down then its this.
2 - The graphics card on your laptop has a fault. This is quite common with laptops that overheat.
3 - The LCD on your laptop has developed a fault.
The first issue can be fixed by taking the laptop apart and checking the cables, but beware - this is normally quite a complex job. The second and third issues will require replacement parts which can be quite expensive. Try to get a quote from a local PC technician (don't go to PC world...) and weigh up if the repair cost is worth it or wether you just just put that laptop on ebay (list it as faulty) and buy a new one.
Hope that helps!
Jul 03, 2012 | ASUS Computers & Internet
Sir i have a Laptop Compaq M2000.There are 9 Colored vertical line coming on my laptop screen.They are started few days ago.Please tell me what to do.
Well this may be due to the inverter board found behind the LCD panel. Try to press around your screen to see if it stops.
You probably need to solder the loose solder of the coil found on your inverter board.
For this, you need to take the screen apart.
Please do send your feedback.thanks.
Feb 11, 2010 | Computers & Internet
I have a white line all the way down my laptop.I have a HP 8110
Any color line that runs the entire length, width etc is a precursor to screen failure. The only other thing it could be is a loose cable on the back of the screen itself. There is a flat 40 pin cable that sends the video signal from the motherboard to the screen, this may have started to work loose but I doubt it. In most cases when you start seeing these lines on your screen it is time to get a new one. You can still use it but you just don't know when it will go out for good.
Dec 20, 2009 | HP Pavilion zd8000 Notebook
Dell 710M display has vertical colored lines instead of info
I suspect that the flat wire between you keyboard and screen is coming loose. It is within one of the himges and is about 1" wide and very delicate. You can not fix it and should take it to someone who works on laptops. Sorry that is the best I can suggest
Jul 14, 2009 | Computers & Internet
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
Problem is related to HP tx1220us tablet PC. Since few days it is giving problem. After 30-40 minutes of working the screen get distorted, it starts showing different colors in the sides and blank from the...
You could try getting a fan for the laptop. I would recommend calling hp and getting an extended warranty (you can still do this even if your laptop is out of warrenty). I think this might be a problem with the motherboard. Lots of people have been having problems with there tx1220us over heating and burning parts up. the next step is your computer will quit booting which is where the warranty will kick in. it will save you about 150 to 250 dollars. Good luck.
Dec 02, 2008 | HP Pavilion tx1220us Tablet PC
Screen Issues
sounds like your video card is starting to fail mite need to install a new one ,need to do assp or mite loose entire system. la la linda
Jun 01, 2008 | Toshiba Portege S100-S1133 Notebook
HP Pavilion Laptop Screen
Bearing in mind you mention the viability of cost, I'm thinking your laptop is out of warranty. This does sound like a pretty major problem, one which HP need to look at. You can always approach them for a quote first, with a min/max price, before you decide whether to go ahead or not.
May 27, 2008 | HP Pavilion dv8000z Notebook
LCD Screen stops working after a while
Your explanation quite clear and understandable that there are some weak shield area and contact issues at Displays connector side. It sound shield/ground issue rather than loose connection. Check the shielding from connection on board to the display module. You may use shielding tape if you have experience to repair electronic devices. You may also take to the Toshiba authorized service center ( Please post your question if you need further assistance
Good Luck
Feb 18, 2008 | Toshiba Satellite A105 Notebook
Screen goes awire?
sounds like a backlight or display power problem.
Oct 24, 2007 | HP Pavilion ze2000 Notebook
HP vs15 15"LCD Flat Panel Monitor Logo
66 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
