Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Brushes can some one please help me with my steam cleaner I have never used it myself but someone else did and Im not sure how to turn the brushs on .....i have never used it
  • 10,865 Answers
Sounds like the belt is broken or at least the brushes are bound up with carpet fibers. Take a look and see which it is.
Posted on Feb 14, 2009
How to clean brushes on hoover steam vac?
Hi, it's Allie from Crucial Vacuum!
Cleaning the brushes on your unit is a very easy and important tank to do! Your deep cleaner is equipped with removable brushes for easy cleaning. First, make sure to remove the clean water tank and recovery tank to prevent possible leaking. Tilt your unit backwards making sure the handle is in the upright position. Grab the brushes and pull firmly. You may clean the brushes with running water. Do not forget to check the brushes for any tangled hair strands or debris that can prevent the brushes from spinning properly.
You can purchase direct your replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
Aug 21, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Power spen brushes move very slow or stop
Not sure if you are speaking of a vacuum or steam cleaner or ?
If it is a vacuum, sounds like the beater brush is freezing up. Follow the directions to replace the drive belt. When you get the beater brush off the unit, clean it as best you can. Add a bit of WD40 between the ends of the beater brush and the hard rubber pieces that hold it in place. Before reassembling, turn the brush while holding the pieces one at a time to be sure the beater brush turns freely. When you reassemble, be sure the belt is properly installed.
If you find this solution to be helpful, I would appreciate an appropriate Thumbs Up rating from you.
Be well, Paul
Oct 06, 2010 | Vacuums
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I was steam cleaning the stair landing and the steam cleaner slipped off the landing a few inches and the brushes haven't worked since
Please remove the brush assembly by pulling down from the bottom of the cleaner. There is a drive pin to the brushes, approximately 1/4 inch square and two inches long that connects the brush to the drive mechanism. You may have broken the pin off, and need to replace the brushes.
Oct 12, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes will not turn. How do I open the unit to put the belt back on?
Hoover doesn't use belts on their steam cleaners. Either the shaft that is on top of the brush block broke off, or the turbine is bad. The turbine is what turns the brushs.
Jun 12, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Steam vac hoover F7458900
There is no belt, the brush block is turned by a turbine. Check the brush block, make sure that the shaft that goes into the turbine isn't broke off, If ok, then replace the turbine, or take it apart and clean it out.
Jun 08, 2008 | Vacuums
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Brushes not turning
Check the shaft on top of the brush block to make sure it hasn't broken, if brush block is ok, then most likely the turbine is bad and will have to be replaced.
Dec 10, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
